blaster
blaster
11/8/09 5:33 p.m.
I am in a bind. I have a camper at Grand Isle, La and hurricane Ida is bearing down hard right now. I have already installed the rails and hitch but was going to have the brake controller installed tomorrow. The problem is I can't wait until tomorrow. They are calling for evacuations now and I need to go get my camper.
I am not a mechanic but I can do most things if told how in simple terms. I was hoping someone out there could walk me through the installation of the controller in my 2003 f-250. It already has the hook up on the rear, factory installed. I'm hoping there is a simple way to do this without having to tear into the wiring. I see 4 wires coming out of the harness as it goes into the engine compartment that are the same color wires as is on the controller. Could I be lucky enough for that to be for the controller pre wired from the factory? Can someone please help?
xci_ed6
xci_ed6 Reader
11/8/09 5:54 p.m.
Check this out: http://www.youtube.com/watch?v=ee8_UUFfK68
cwh
cwh SuperDork
11/8/09 5:59 p.m.
Good luck, storms can be a real bitch. I would go get it even if the good stuff was not hooked up yet. I've been through too many hurricanes. Do not hesitate, GO!!!
blaster
blaster New Reader
11/8/09 7:42 p.m.
Thank you very much for the link. I don't have the adapter but at least I know what wires to splice to. That did the trick. Again, thanks. By the way, I hate hurricanes! I'll be leaving shortly headed that way.
44Dwarf
44Dwarf HalfDork
11/8/09 8:31 p.m.
It should be wired from the factory BUT...likely will not have the two relays under the hood. www.fordtrucks.com will help ya.
44
oOBrDdCwm0PowSRHKbXAZQLTEzNG6MNlC7vZdWZPruB7KtB8wJdTzseF5wIrviMw
