ultraclyde
ultraclyde UltraDork
3/5/15 1:43 p.m.
For all you fellow science geeks out there...quick blurb about research into carbon nano-balls as an oil additive.
http://www.rdmag.com/news/2015/03/sub-micrometer-carbon-spheres-reduce-engine-friction-oil-additive?et_cid=4447275&et_rid=744725318&location=top
D2W
D2W New Reader
3/5/15 1:51 p.m.
Ultra cool technology. Did someone say Super Synthetic.
BeardedJag
BeardedJag Reader
3/5/15 1:55 p.m.
That is pretty nifty. I dont know that I would put something like "ball bearings" in my engine until I have seen running test to show that it can handle the stress. If it can, they could on to something pretty cool.
bgkast
bgkast UltraDork
3/5/15 2:53 p.m.
Isn't nanotechnology fun!
Junkyard_Dog
Junkyard_Dog SuperDork
3/5/15 4:20 p.m.
bgkast wrote: Isn't nanotechnology fun!
Sure! right up until you're assimilated.
foxtrapper
foxtrapper UltimaDork
3/5/15 7:15 p.m.
Arco graphite makes a comeback!
Leafy
Leafy HalfDork
3/5/15 7:30 p.m.
So they're 0.1-0.5 micron. I just had to double check and make sure that they hadnt made a fatal flaw in their plan. For reference most car oil filters are 25-30 micron some do go as low as 10 micron.
Knurled
Knurled UltimaDork
3/5/15 7:45 p.m.
D2W wrote: Ultra cool technology. Did someone say Super Synthetic.
Sorry, I couldn't hear you over Arco Graphite.
Knurled
Knurled UltimaDork
3/5/15 7:46 p.m.
In reply to foxtrapper:
Missed it by THAT much!
84FSP
84FSP Reader
3/5/15 9:14 p.m.
Nano particles are actually really scary stuff. Very little science around them and no discernable method to control them once they leave the container.
Tom_Spangler
Tom_Spangler SuperDork
3/5/15 9:45 p.m.
foxtrapper wrote: Arco graphite makes a comeback!
Holy crap, there's a blast from the past. I think my dad used to use it on his guns back in the 70s.
former520
former520 Reader
3/5/15 10:13 p.m.
84FSP wrote: Nano particles are actually really scary stuff. Very little science around them and no discernable method to control them once they leave the container.
I concur, are we not already having trouble with the little micro beads that are in our soap? What will happen in 25 years of this stuff being pour in the drain, leaked in parking lots, burning through exhaust (would they even burn).
Then again, by the time this stuff is out, we will all be driving composite cars with electric motors and not using much of the stuff anyway outside of industrial applications.
The0retical
The0retical HalfDork
3/5/15 10:35 p.m.
In reply to former520:
The buildup of microbeads is due to the fact that they are lighter than water. Thus not being filtered by the centrifugal waste separation process.
They're also quite a bit bigger than .5 micron so its not really an apples to apples comparison.
It should probably be studied a bit more but I don't see how it would be worse than most oils consumed in an ICE. Especially since there are <1 micron filters in existence.
Leafy
Leafy HalfDork
3/6/15 6:24 a.m.
The worry is nano particles in the air, and they'd get there from the motor oil past the piston rings. Remember asbestos is the first nano material and the only naturally occurring one, and I read an article in a science journal about how some carbon nano tube researchers had started to show the same symptoms as asbestos workers. I never saw a follow up.
67King
67King New Reader
3/6/15 9:42 a.m.
Several things. First and foremost, when I read the article, there is no mention of "nano" in it. The spheres are an order of magnitude larger than typical nanotechnology fullerenes, two orders larger than a typical carbon nonosphere. Carbon was the first known NT material, typically a 60 atom sphere, a "Buckminster fullerene," or "Buckey Ball" as they are known. Their structure looks just like a soccer ball with the alternating hexagrams and pentograms. A C60 fullerene is about 10 Angstroms in diameter.......or 1 nanometer, or 0.001mm. I may be mistaken, but I do not believe the structure of the substance in the article is a fullerence, which is what defines nanotechnology.
Second, NT (the real, known stuff) has been researched in oils for 10 years or so. SOme of the earlier research was not very favorable. However, more recent research has been much more favorable. Full disclosure, I'm the importer/NA distributor of Millers Oils. Millers introduced NT in gear oils in 2009, and has been recognized with some very prestigious awards, mostly in Europe (they are British). SAE has published a few articles on them, http://articles.sae.org/11201/ - Nano-based lubricant from Millers Oils......, http://articles.sae.org/12798/ - Oiling the Way to Greater EV Efficiency, and most recently http://articles.sae.org/13903/ - Racing to Solve the Lubrication Challenges of Start-Stop Engines.
Now for the technical aspects of the paper. You absolutely CANNOT extrapolate reduction in wear to fuel economy as they state. The mechanisms are COMPLETELY different. Wear occurs from boundary lubrication, when you have metal to metal contact. That occurs in very few places in the engine. It does occur at start up. It occurs very infrequently in the cranktrain, but only with the thinner and thinner oils to which we are migrating, and under extreme circumstances. It does occur in one place on a regular basis, the piston ring/cylinder interface, BUT......only close to TDC and BDC. The mechanism is that when the piston stops and changes direction, the hydrodynamic wedge breaks down. Everywhere else in the engine, you have hydrodynamic lubrication, meaning a film of oil separates the metal components. Furthermore, only about 20-30% of IMEP is lost to FMEP. The means there ALL sources of friction, including pumping losses of air and coolant, is on the table. Of all sources, the piston and rod assembly is roughly 30% of the total. That means that your opportunity for FMEP reduction is under 10%. Now if you reduce the coefficient of friction by half, then you are talking 5%. This is oversimplifying it to a large degree, as it doesn't account for partial load, or lower than peak power RPM. But it should be enough to give a good idea.....
*IMEP - Indicated Mean Effective Pressure. That is how much specific/normalized torque (torque per unit volume) an engine makes before frictional losses. Thermal efficiencies are already accounted for at this point, but mechanical efficiencies are not. FMEP, or Friction Mean Effective Pressure is specific torque lost to friction. BMEP, or Brake Mean Effective Pressure is specific torque as rated.
Health concerns. First, the concentrations in the finished product are WAY less than in the article mentioned. Precise amount is proprietary. Second, the concerns raised and being researched by the CDC and NIOSH are for nanotubes and nano-fibers, and NOT nanospheres. Papers specifically call out "large aspect ratio" structures. The belief is that the feature size is too small (the NT used in Millers is layered, unlike a C60, so it can be 30-100nm) to be able to pierce cells the way that asbestos does. I am only left to speculate here, but the tubes and fibers can become oriented like needles, whereas spheres can't really be oriented in such a way that they can cause lacerations in cells. NOt an expert, I'm an engineer, not a biologist! Third, the feature size of the sphere is so small that it is NOT going to become airborn. Van-der-Waals forces will keep the NT particles sticking to surfaces. The NT in the Millers quickly migrates to the metal surfaces in the engine, and stays there, even after the oil is drained (it will eventually be depleted if a non-NT oil replaces the NT stuff). This is why it takes TONS less than 3% of NT for it to work (and higher concentrations have actually shown to be detrimental from early research). But more importantly, there is virtually zero risk to exposure of this stuff if you use it in an oil. The only real concerns NIOSH has is for workers exposed to it (again, not the spherical form) in its manufacture.
The articles linked mention wear reduction a few times. And Millers has shown that the oil's coefficient of friction can be cut nearly in half. But like I said, it doesn't correlate directly to fuel economy. Many dyno tests have been run by 3rd parties, and we've seen up to a 5% increase in peak power over fully synthetic street oils. 1-2% over other similar race oils is more typical.
FWIW, so y'all can gauge the competence of my comments, I have a couple of degrees in Materials Engineering from Georgia Tech, and did engine development for Ford for 7 years before relocating and doing what I do now.
Joe Gearin
3/6/15 11:15 a.m.
Thanks Harry--- good reading.
Jaynen
Jaynen Dork
3/6/15 12:27 p.m.
Awesome love technical info posts like this.
ZvgFjqTfvbcq7ecFtyTbeR8nUnhyBYeEu0w4y9YPevK3LDo5HsSVhO3Bw1BqiFPC
