Feedyurhed
Feedyurhed UltraDork
7/31/22 8:26 p.m.
1972 Mercedes Benz 450SL complete with factory removable hardtop and Bobby Nichols golf clubs. I am just not sure how this even happens.
Streetwiseguy
Streetwiseguy MegaDork
7/31/22 8:44 p.m.
Estate cleanup, I'd bet.
Tk8398
Tk8398 HalfDork
7/31/22 9:18 p.m.
I have seen so many like that or nicer in CA junkyards.  They sit too long and won't run well enough to pass emissions testing anymore and nobody cares enough to try to fix them anymore.  Modern fuel with ethanol wasn't any help either.
dean1484
dean1484 MegaDork
7/31/22 9:48 p.m.
Ok considering what we see up here that is in darn nice shape.  My first thought is to 6l Vortec swap it.
frenchyd
frenchyd MegaDork
7/31/22 9:56 p.m.
In reply to Tk8398 :
That's exactly what happens to a lot of Jaguars. Daddy's retirement gift for a lifetime of hard work and sacrifice.
 Daddy gets old  it gets used less and less finally won't start or Daddy loses his license.
  It will cost too much to get running and fix it. Tires in good shape except they are 20+ years old.  That's where they wind up.
7/31/22 10:00 p.m.
In reply to frenchyd :
Unfortunately, you are right.
Run_Away
Run_Away Dork
7/31/22 10:01 p.m.
So how much were golf clubs on the junkyard price list?
I'd probably buy the hardtop too because I'm a hoarder and can't bear to see good rare parts scrapped.
Feedyurhed
7/31/22 10:18 p.m.
That's exactly like me. The removable hardtop was unbelievably listed for only $50.00 but I have no way to get it home. I too hate to see it go to waste. Somebody is likely looking for one of those.
Steve_Jones
Steve_Jones Dork
7/31/22 10:46 p.m.
In reply to Run_Away :
I'm pretty sure they all came with a hard top, at least it seems that way. I'm not sure I've ever seen one for sale without it.
stuart in mn
stuart in mn MegaDork
8/1/22 1:25 a.m.
Buy it, and build a replica of this:
chandler
chandler UltimaDork
8/1/22 4:47 a.m.
107 hardtops are pretty well free for this reason. 129 is similar, look for a pano roof though....
frenchyd
frenchyd MegaDork
8/1/22 8:32 a.m.
Amen!!!!
   Race cars are cheap to build and give great performance.  You can either license them for the street. Or eliminate a lot of wiring and put all new wires in.  That part is really basic.
     Don't bother to rebuild most engines.  Just throw a turbo on them to kick up performance. Most every engine will tolerate 6 PSI.  High mileage helps because it wears out piston rings  to open up the ring gap.  Which typically is the one mechanical bit you need to do to use Turbos.  You will need extra fuel for the extra power you make.
   I'll have to check but we put about $300 worth of tubing in the Jaguar.  To build a legal cage.  Wheels,  tires,  etc. you can finish one off for about $2000 ( less if you're good at scrounging)  and a lot of work.
I don't know anything about Mercedes Benz but every Jaguar I've torn apart has mostly good mechanical parts.  I'm sure just like Jaguars Mercedes Benz have networks of more affordable parts  and parts interchange to get more performance at a modest cost.
spitfirebill
spitfirebill MegaDork
2/22/23 9:51 a.m.
Title issue.
californiamilleghia
californiamilleghia UberDork
2/22/23 10:45 a.m.
If they are anything like 996 Porsche hardtops , there are many more hardtops than buyers as they take up a lot of garage floor when taken off and it's not a one man job....
I sold my 996 hardtop for $200 because no one wanted it......yes I see them advertised for 1000s  but they never sell....
frenchyd
frenchyd MegaDork
2/22/23 10:53 a.m.
spitfirebill said:
Title issue.
Race cars don't need tittles.
    Once gutted and stripped of luxuries like a race car is. They aren't that heavy.
 My Jaguar XJS  with a 700 pound motor  and 300 pounds of tubing for the roll cage weighs 2700 pounds.  It starts out as 46XX.
     Properly balanced and the trailer aligned a single axle open deck trailer  is sufficient.   And tows easier than a tandem axle trailer.  Plus moves around easily without being hooked to the tow vehicle.
   A truck, SUV,  or suburban painted to match the race car would look cool and you could buy one of those with plenty of life left in it cheap if the paint is bad.   Torn up interior can be replaced cheap at the junk yard.
       Two things change that to a + 500 hp rioarity car.   $135 Amazon Turbo ( $50 waste gate)
      And converting the stock ECM  to aftermarket like Megasquirt. That's so you can  add a inline fuel sensor to use E85.   I know you don't know where to buy it.  But just have it shipped to you from places like VP fuels.  Even with shipping it's cheaper than Premium at the gas station.   At some point you down load the app to find E85.
    Here's why.  You gain 10-20% more power   Just using it.  Plus it runs cooler which helps so you can use the stock radiator.  Etc.
  Then it helps doubly  because if the engine has around 100,000 miles on it the rings will be worn enough to use over 20 PSI  boost  so now you're up near 700 hp.
frenchyd
frenchyd MegaDork
2/22/23 10:54 a.m.
I always see them hanging from rafters when not in use.
benzbaronDaryn
benzbaronDaryn SuperDork
2/22/23 10:56 a.m.
Grab the bumpers, they are worth money.  I would buy them if shippable to CA.  Also check truck for rubber floor mat, another $$$.  The distributor and fuel pump are d jet only.  Small chrome side mirrors, brass radiator overflow. Lots of pricy parts on early 107.  The hardtop is worthless.
Somebeach (Forum Supporter)
Somebeach (Forum Supporter) Dork
2/22/23 2:09 p.m.
Beautiful car!
2/22/23 6:52 p.m.
I would expect that all to be gone in the half year since this was originally posted.
benzbaronDaryn
2/22/23 7:54 p.m.
It it a a beer Stein by now, wanna find a set of bumpers for a dumb idea.  The early cars are near but the stupid d jet is $$$ to maintain.
frenchyd
frenchyd MegaDork
2/23/23 1:21 p.m.
In reply to benzbaronDaryn :
What I don't understand is why The ECM of the 70'-80's-90's isn't just yanked out and replaced with  a Megasquirt,  Maxx or one other other  ECM's available that are self learning and all you have to do is get the wiring right?
       There is a guy over in England charging big dollars  for plug and play versions of the Jaguar.
      Once you've got a wiring color chart  and a sample just how hard would it be?
Ian F (Forum Supporter)
2/23/23 1:32 p.m.
frenchyd
frenchyd MegaDork
2/23/23 1:47 p.m.
Pretty straight forward on Jaguars.  But I don't know Mercedes, BMW, or American cars.
     I do know I was terrified until I actually sat down with the shop manual and watched A Few ( a lot ) of U tube video's.
The final one is when I watched a guy down in Texas  just go straight ahead and goober one up.  The " gas tank" was an old fire extinguisher that he kept forgetting to turn on.  Crank crank crank " is the fuel pump on?" Oops click VAAROOOM. !
  Just odd pieces of wiring hooked into a 2nd hand mega squirt he paid $150-200? For.
buzzboy
buzzboy SuperDork
2/23/23 6:12 p.m.
The CIS can be swapped to MS but it isn't just a bolt on. Friend has a 'squirted 560SL and it's never quite run right. Lots of weird parts in the factory setup to be replaced or modified.
frenchyd
frenchyd MegaDork
2/23/23 6:44 p.m.
In reply to buzzboy :
Oh that's disappointing.  On a Jaguar it's really straight forward.  In fact when I first went on the site for Jaguars  the few guys were arguing about stuff that doesn't really make any difference in how it runs.  Most cars of that era are batch fired when it comes to fuel injectors.  They let the camshaft decide when the fuel actually goes into the cylinders.   Its not sequential from the factory. It's real nonsense stuff that the basic Mega squirt doesn't have the ability  to adjust. ( not enough inputs/outputs).
 You need to go up to the Mega squirt gold box if you  want to play with that.  But if you do mess with sequential timing of the fuel. That's how to put back in smooth idle, easy starting, etc.  you can also mess with ignition timing.  And go to  stuff like flex fuel and boost!!!
  Then the guy in Texas was hooking right up to the various points needed. He didn't care a hoot if  it was analog or digital.  It worked!!
      Yeh there was some misfiring etc.  but considering the shape the rest of the car was in  the doubt those were the trouble with the ECU. And just misadjusted  throttle, bad plugs or clogged injectors etc.
      there is nothing magic about those ECU 's they don't fix stuff so if the engine was running rough because of plugged injectors or bad plugs etc.  switch to the aftermarket isn't the big red easy button.  What it does do is eliminate vacuum leaks because it doesn't use vacuum inputs. But yeh. Too much air will get in and cause backfiring.  Do you need to plug those.
    As far as sophisticated running, like dealing with the A/C kicking on and off.  Nope!    Race cars don't use  A/C    But you can fix all that stuff yourself.  I just wouldn't mess with a street car.   What aftermarket ECU's allow you to do is make more power than the factory's feel comfortable. Turbo charge a car? Yeh! E85 a car? yeh!!!  Camshafts and compression oh my!
  I don't know diddly squat  about NOS.   But in a heavy high geared car like a 560?   It would take a massive amount to keep up with the little imports.
     It's like this.  If you want to race a big heavy car. Against a light little import? The money demand is too massive to contemplate.
  That's why all the luxury stuff is pulled  out to get the weight closer.  But the big V12/V8  starts out with a serious power advantage and takes boost  like a duck to water.
    Once the weight is close the bigger engine has the advantage. As is said. There is no replacement for displacement.
4aBnYhetBXih5A4DaI4dfKgpe16lcK814x25AlYnIeAgpJ77oSOTDjniL1uGS3OF
