mrwillie
mrwillie Reader
4/20/11 11:43 a.m.
Is there a place I can check or info to look for that will tell me if an engine is interference or not? I'm helping a nephew find a first car, and alot of the ones in his price range need the timing "adjusted" ( per the PO ), or actually say that they need a timing belt. I had been telling him to pass on those, but having a second thought about it, it could be used as a bargining tool. He does not have alot of money right now, or a place to do an engine swap or get machine work done. So cars w/ engine damage are off the list.
Thanks. Will
mad_machine
mad_machine SuperDork
4/20/11 11:44 a.m.
if it needs a timing belt, but still runs.. Use it as a barganing point and use the money saved to do the belt.
oldtin
oldtin Dork
4/20/11 11:50 a.m.
16vCorey
16vCorey SuperDork
4/20/11 11:51 a.m.
I usually just google the year, make, model, engine size, and the word "interference". Something always comes up that tells me if it's a interference or non-interference engine.
nderwater
nderwater HalfDork
4/20/11 12:45 p.m.
Not to get into the weeds here, but I've always wondered why car companies sell interference engines fitted with timing belts instead of timing chains. Do they want you to grenade your engine?
Strizzo
Strizzo SuperDork
4/20/11 1:01 p.m.
if its a fairly common car, you can call autozone or the like and have them look up a timing belt, it will usually tell you if the engine is interference as well.
nderwater wrote: Not to get into the weeds here, but I've always wondered why car companies sell interference engines fitted with timing belts instead of timing chains. Do they want you to grenade your engine?
NVH
mrwillie
mrwillie Reader
4/20/11 1:27 p.m.
Well, I thought that some belt engines were non-interference? For instance, older 1.8L VW engines had belts but were non-interference( I thought they were anyway). And also, most of the google searches I've done have giving conflicting info at best but usually no help at all. i'll check out the above links though.
Thanks.
triumph5
triumph5 Dork
4/20/11 1:34 p.m.
A timining chain is noisier and costs more than a belt. Also moe flexible in some applications. It's also extoronomics for the dealers' service dept. ..
KATYB
KATYB Reader
4/20/11 1:48 p.m.
noise vibration harshness and cost. notice tho most companies are now getting rid of belts. also with the exception of pt cruisers i have never seen a car throw its tbelt before the rec interval... pt cruisers are special tho.
Bobzilla
Bobzilla Dork
4/20/11 2:43 p.m.
^ And Daewoo's. THe Leganza's were throwing thier OE Gates belts at ~42k miles and bending every intake valve in sight.
fast_eddie_72
fast_eddie_72 Dork
4/20/11 2:59 p.m.
I dunno, the only timing device I have ever had fail was a chain. They're not a guarantee, and I didn't know that. So my motor go boom.
16vCorey
16vCorey SuperDork
4/20/11 3:03 p.m.
On top of all that they really aren't that much better. See GM Ecotech and Ford 4.0L SOHC engines for example. They eat chains like there's no tomorrow, and they don't even have a recommended service interval. I've much rather have a 60k mile service interval than the false sense of security of a chain that's supposed to last forever, but will probably destroy my engine.
16vCorey
16vCorey SuperDork
4/20/11 3:05 p.m.
Ha! you wrote that while I was writing something similar. Was it a GM Ecotech or Explorer 4.0L SOHC engine?
Cone_Junky
Cone_Junky HalfDork
4/20/11 3:11 p.m.
VW 1.8T's were blowing tensioners at 70K on 105K interval belts. Sometimes it not only took out the valves, but damaged the block too.
Rusted_Busted_Spit
Rusted_Busted_Spit Dork
4/20/11 3:19 p.m.
All things being equal I would rather have a chain than a belt, I have put close to 300k miles on motors with chains without an issue. With that being said when we got married my wife had a 90 Celica GT that had a belt. That motor was noninterference so we just drove it until the belt broke and then repaced it.
Otto Maddox
Otto Maddox HalfDork
4/20/11 3:26 p.m.
oldtin wrote: http://www.aa1car.com/library/timing_belts_interference_engines.htm
I think the last time that list was updated was before the internet even existed.
spitfirebill
spitfirebill SuperDork
4/20/11 3:32 p.m.
The 3.4 V6 in my 4runner is belt drven and non-interference.
oldtin
oldtin Dork
4/20/11 3:42 p.m.
Your probably right - included the gates web tool for more "timely" info
Otto Maddox
4/20/11 3:59 p.m.
In reply to oldtin:
Yeah, I used that to confirm that my household's daily drivers are both interference.
KATYB
KATYB Reader
4/20/11 4:05 p.m.
Bobzilla wrote: ^ And Daewoo's. THe Leganza's were throwing thier OE Gates belts at ~42k miles and bending every intake valve in sight.
ok well seriously its a daewoo!!!!!!!!!!!!!!!!!!!!!!!!!!
mrwillie
mrwillie Reader
4/20/11 4:41 p.m.
Ok. So the Gates link is a safe tool to use for determining interference vs non-interference?
iceracer
iceracer Dork
4/20/11 4:43 p.m.
Use any list with a grain of salt. Most lists say the Zetec is interference. It is not. From experience.
iceracer
iceracer Dork
4/20/11 4:48 p.m.
I just looked at that list. It has a bunch of errors. The Escort CVH engines are all non-interference. Again, from experience.
KATYB
KATYB Reader
4/20/11 5:12 p.m.
iceracer no they are not....bent valves on a 89 escort gt to prove it. they were close to it but it is possible to hit the valves. afaik the zetec was only interference on the vvt versions.
93gsxturbo
93gsxturbo HalfDork
4/20/11 6:08 p.m.
I prefer timing gears. No chains to stretch, no belts to get oil soaked and fail.
FHIK2eP2CUknH0DaaGtyiXLr2HBMQJu1vDiB6Rd9aVhmZNyXfPyCHP0QpLQw28H8
