singledownloop
singledownloop New Reader
10/15/14 10:10 p.m.
Will a sbc bolt in place of an 1982 iron duke engine with just different motor mounts?
Streetwiseguy
Streetwiseguy PowerDork
10/15/14 10:25 p.m.
Note- the following is all rumor and innuendo:
At some point, the trans bolt pattern was changed to the 2.8 V6 pattern, at least on the front drive blocks, I think. If its old enough and rwd, its possible, maybe.
singledownloop
10/16/14 2:17 p.m.
It's in an amc spirit and has the standard(V8-etc)chevy trans bolt pattern.I'm trying to find out if I can use "off the shelf" parts to bolt the sbc in place of the 151 iron duke engine.
Kenny_McCormic
Kenny_McCormic PowerDork
10/16/14 2:21 p.m.
You'll likely need to fab mounting brackets, not hard.
pres589
pres589 UltraDork
10/16/14 2:22 p.m.
What trans is in the car?
OldGray320i
OldGray320i Reader
10/16/14 2:29 p.m.
This makes me think an SBC in the '84 Buick Skylark I had years ago would've been a hoot in a straight line. Not sure it'd have been able to turn a corner, though....
tuna55
tuna55 UltimaDork
10/16/14 2:31 p.m.
OldGray320i wrote: This makes me think an SBC in the '84 Buick Skylark I had years ago would've been a hoot in a straight line. Not sure it'd have been able to turn a corner, though....
Uhh, the 84 was transverse FWD dude...
singledownloop
10/16/14 5:10 p.m.
A little more research I found that the first generation S10 used this engine.I've been on the jags that run site and they have everything to bolt sbc including the LS in the S10.This is of course an amc spirit not a S10 but I'm a betting man so I think I can use there engine plates and mount to V8 my amc.It was luck that I noticed the S10 used the same engine I have.
singledownloop
10/16/14 5:13 p.m.
pres589 the car has a 904 mopar transmission with the sbc bellhousing.Not good at explaining things,basically it's a mopar trans that'll bolt to any sbc.
pres589
pres589 UltraDork
10/16/14 8:22 p.m.
904 should handle an average SBC. Kind of a cool piece. I wonder if the 904 is more efficient than a TH350 or 200-4R as far as power absorbed by the trans itself. Apparently a lower gear ratio setup was put into the 904 around 1981; wonder what's in your car.
Good luck with the swap.
Gearheadotaku
Gearheadotaku PowerDork
10/16/14 10:02 p.m.
Yeah so? I've seen SBC's transversed into Chevy Citations using Fiero V8 install kits. Skylark was same platform in '84.
(Didn't say it was a good idea, just possible)
novaderrik
novaderrik PowerDork
10/17/14 2:05 a.m.
i'd love to see a pic of an Iron Duke with the Chevy small block bellhousing pattern- they had the BOP (Buick, Oldsmobile, Pontiac) bellhousing pattern when they were putting them in rwd Monzas and what not in the 70's, then they got the standard GM fwd bellhousing when they started putting them in the fwd cars in the 1980 model year. the rwd F bodies and S trucks of the 80's used the fwd bellhousing pattern, too.
never seen or heard of one with the Chevy bellhousing- not saying they didn't make them, but this is the first i've ever heard of it.. and if it was common to use the Chevy bellhousing in AMC products, then there would be more Chevy small blocks swapped into them and those transmissions would be getting swapped into Chevy powered cars..
if it has the old BOP pattern, then you can get an adapter to bolt a small block Chevy to the trans. i believe you can get an adapter for the smaller fwd pattern, too.
moparman76_69
moparman76_69 SuperDork
10/17/14 5:30 a.m.
singledownloop wrote: pres589 the car has a 904 mopar transmission with the sbc bellhousing.Not good at explaining things,basically it's a mopar trans that'll bolt to any sbc.
singledownloop
10/17/14 10:24 a.m.
novaderrik just google amc iron duke 904 transmission and you can see all the pictures and learn all you'd like to know about this transmission.I didn't think you doubted me and I'm glad I could enlighten you on this transmission.
singledownloop
10/17/14 11:06 a.m.
Information with pics
http://www.jalopyjournal.com/forum/threads/id-this-transmission.938695/
singledownloop
10/17/14 11:04 p.m.
iadr I'm super interested in your engine build.Do you have any pics you can share.I plan to convert this engine to efi.Did you go with megasquirt or what system?
pres589
pres589 UltraDork
10/17/14 11:49 p.m.
In reply to iadr:
uhm, what?
novaderrik
10/18/14 9:01 a.m.
pres589 wrote: In reply to iadr: uhm, what?
i think what he said was that he just outdid anything AMC ever did in the field of using parts from every manufacturer on the same engine..
novaderrik
10/18/14 9:06 a.m.
i think i need to find one of those AMC/Iron Duke manual trans bellhousings and a T5 out of a later 3.8 powered Camaro or 90's Mustang for my Camaro.
Knurled
Knurled PowerDork
10/18/14 9:07 a.m.
iadr wrote: I'm using 80-81 Jeep parts- bellhousing, clutch lever- to mate a SBC patterned Mercruiser 3.7L 4 block to a G-force Racing-rebuilt T5 from a 1994 Ford Mustang V6,
So, to recap:
Half a 460, with a Chevy bellhousing pattern, and you need a Jeep bellhousing to make it bolt up to a Ford transmission.
Man, sometimes things get awful inbred.
Wait, Boss 429 head? (thisthreadisuselesswithoutpics.jpg)
Knurled
Knurled PowerDork
10/18/14 9:10 a.m.
novaderrik wrote: i think i need to find one of those AMC/Iron Duke manual trans bellhousings and a T5 out of a later 3.8 powered Camaro or 90's Mustang for my Camaro.
The 3800 T5s have a longer input shaft than the 90s Mustang units. (Or was that the point?)
For that matter, so do the SN95 V6 T5s. I think what happened was, Chevy stopped using the T5 except for V6s models, so to save money, they were just ordering Ford-pattern boxes, and Ford went to a longer input, so Chevy did too. The only hole in that is the 4th-gen F-body came out before the SN95.
novaderrik
10/18/14 2:04 p.m.
The 3800 T5s have a longer input shaft than the 90s Mustang units. (Or was that the point?) For that matter, so do the SN95 V6 T5s. I think what happened was, Chevy stopped using the T5 except for V6s models, so to save money, they were just ordering Ford-pattern boxes, and Ford went to a longer input, so Chevy did too. The only hole in that is the 4th-gen F-body came out before the SN95.
Bolt pattern where the trans bolts to the bellhousing is different on the Ford and 3.8 F body than on other GM transmissions. Older F body T5 is weaker and the people that have them think they are worth their weight in gold, but the 3.8/Mustang T5 is stronger and cheaper.. AMC bellhousing could be a cheap junkyard alternative to an aftermarket bellhousing to hook a Ford pattern trans to a Chev engine.
singledownloop
10/20/14 7:22 p.m.
What engine mounts and frame mounts should I use to put the sbc in place of the iron duke?Since the S10 came with an iron duke like my spirit could I use conversion mounts from "jags that run" S10 V8 swap or is there a better option?
81cpcamaro
81cpcamaro HalfDork
10/20/14 7:46 p.m.
Summit has the engine and frame mounts for the 4 to V8 here: http://www.summitracing.com/parts/trd-4516
Kenny_McCormic
10/20/14 10:29 p.m.
In reply to singledownloop:
If it shares mount with the 2.5 S10 yes, if not, it's be easier to just weld up a pair of brackets.
LfliWo5mzbbopexyrq7PVulUjfzpybqHBqtL8JLEt0YCM2SxuTAATDhSjg9fwaaF
