novaderrik
novaderrik PowerDork
10/21/14 2:21 a.m.
81cpcamaro wrote: Summit has the engine and frame mounts for the 4 to V8 here: http://www.summitracing.com/parts/trd-4516
that would work if he was putting an LS engine (5.3, etc.) in an S10 that originally had a 2.8.. won't work on a gen 1 small block, and probably not in an AMC..
personally, i'd just fire up the welder and make frame stands starting with some cheap aftermarket polyurethane Chevy "short and wide" mounts bolted to the engine...
81cpcamaro
81cpcamaro HalfDork
10/21/14 8:59 a.m.
Opps, my bad, need to read the description better. Sorry.
that would work if he was putting an LS engine (5.3, etc.) in an S10 that originally had a 2.8.. won't work on a gen 1 small block, and probably not in an AMC.. personally, i'd just fire up the welder and make frame stands starting with some cheap aftermarket polyurethane Chevy "short and wide" mounts bolted to the engine...
wspohn
wspohn HalfDork
10/21/14 11:14 a.m.
novaderrik wrote: i think i need to find one of those AMC/Iron Duke manual trans bellhousings and a T5 out of a later 3.8 powered Camaro or 90's Mustang for my Camaro.
Be careful what you put in front of a T5 and which trans it is - they have limited torque capability, even the WC series. GM only used them with their wimpiest V8s and a torque ceiling of around 300 ft lbs is a wise limit.
This is a useful guide http://www.flatheadv8.org/ernie/ernie-t5.htm
I use a WC T5 in my Jamaican MGA.
KsuCFnFBPlPyI6mfGBHMRMhQC9p1WAtl775YghpoQNb4C0BgJIczdLK5NiBEqixI
