Datsun310Guy
Datsun310Guy UltimaDork
11/18/19 6:37 p.m.
Opposite thread.
Clutch on my Datsun 310GX engine and tranny never move.  Remove upper trans cover, slide gear cluster thru wheel well and unbolt clutch and replace.
Mndsm
Mndsm MegaDork
11/18/19 6:39 p.m.
Alternator on my corolla. 3 bolts. It's on top of the engine.
vwcorvette
vwcorvette UltraDork
11/18/19 6:45 p.m.
Clutch on Saab 900 turbo with air. Just remove the hood for access. Now about that water pump.
wheelsmithy
wheelsmithy SuperDork
11/18/19 6:50 p.m.
ACVW engine/ main seal. My wrenching sensei and I once drove a bug in, replaced main seal, and drove it out in less than half an hour.
buzzboy
buzzboy HalfDork
11/18/19 6:55 p.m.
Literally anything engine related on an ACVW. Even building the thing is quick and easy.
rslifkin
rslifkin UltraDork
11/18/19 6:58 p.m.
Motor and trans mounts on my E38.  Most cars it's a pain in the ass with wiggling things around for alignment, trying to get to the mounts, etc.  On this thing, you just jack up the motor or trans, find the right set of sockets and extensions for the motor mounts and the right box wrench for the trans mounts and go at it.
Trans mounts are remove 2 nuts per mount, slide the 2 mounts out, slide new ones in, install nuts.
Motor mounts are drop undertray, remove 3 nuts per mount, disconnect secondary air pump hose so you don't break it (don't ask how I know that).  Jack up engine, wiggle / rotate old mounts out and new ones in, lower engine, install nuts, connect hose.  All shockingly quick and easy (and surprisingly cheap too).
Jay_W
Jay_W Dork
11/18/19 8:08 p.m.
Oilchange on w211 e55. 2 drainplugs, no big deal, but the filter is right up top front corner and makes for the World's Easiest Oil Fill.  And though you can't bleed the brakes without a diagnostic computer, you can change brake pads in minutes. 2 bolts removes caliper, 2 spring clips and pins locate 4 pads. Done and done.
aircooled
aircooled MegaDork
11/18/19 10:20 p.m.
Entire drivetrain on early Corvair.  Engine and transaxle on the floor in about 30 min if you are prepared.  Lates are a bit more involved but not terrible.
11/18/19 10:39 p.m.
I can change the oil on my FR-S without jacking up the car.
Now that I think about it, I can do that on the Focus wagon as well.
JoeyM
JoeyM Mod Squad
11/18/19 10:51 p.m.
swapping the fuel pump on a 1982 maxima wagon was easy because the pump was external to the fuel tank, and the hoses were long enough to clamp with vice grips.
ShawnG
ShawnG PowerDork
11/18/19 11:11 p.m.
Timing chain on a Ford 4.9 I6...
Never wears out because gears.
Boost_Crazy
Boost_Crazy HalfDork
11/18/19 11:36 p.m.
Ford Contour V6 water pump. Run off the back of the head, up on top easy to access. I think I spent more time picking up the replacement at the parts store than changing it.
Knurled.
Knurled. MegaDork
11/19/19 5:57 a.m.
Engine R&R on any naturally aspirated Subaru.
AngryCorvair
AngryCorvair MegaDork
11/19/19 6:20 a.m.
Early, an hour if it’s your first time, otherwise 30 minutes max.  Late, add 15 minutes.
Coolant flush is even easier.  ;-)
egnorant
egnorant SuperDork
11/19/19 6:21 a.m.
I changed heater cores on my 91 Ford Ranger AND my 91 Escort on the same day.  The easiest AND the most difficult change I have ever done!
Bruce
spitfirebill
spitfirebill MegaDork
11/19/19 6:43 a.m.
You mean they never “improved” them with self destructing plastic gears?
spitfirebill
11/19/19 6:45 a.m.
Pretty much anything on a Spitfire except removing the rear hubs.  And if you have the correct tool, that’s a piece of cake.
Ian F
Ian F MegaDork
11/19/19 6:47 a.m.
Water pump on an 1982 Subaru w/o A/C or P/S.  You pop the hood and there it is.
therieldeal
therieldeal Reader
11/19/19 7:27 a.m.
Bruce
I will second this, I could not believe how easy the heater core was on my 89 Ranger.
Oddly enough my prior experience with such things was on an Escort.....
RealMiniNoMore
RealMiniNoMore PowerDork
11/19/19 7:30 a.m.
I was going to post a thread just like this, with this very car /job.
bluebarchetta
bluebarchetta Reader
11/19/19 9:30 a.m.
Fuel pump on a 3rd-gen Odyssey.  You know how, on many vehicles, you wish there was a trap door in the floor to access the pump so you don't have to drop the tank?  On the Odyssey, there is one.
11/19/19 9:39 a.m.
Oil and automatic transmission fluid on a Subaru with the EJ22.  You can change the oil from the front of the car without jacking it up.  And the trans has a drain plug and a spin-on filter, both no harder to do than an oil change on a regular car.
NOHOME MegaDork
11/19/19 9:46 a.m.
Oil filter access can't be any easier.
kevinatfms
kevinatfms Reader
11/19/19 9:56 a.m.
Single stoutest engine ive ever worked on. Ford built them ridiculously tough.
ProDarwin
ProDarwin UltimaDork
11/19/19 10:00 a.m.
A Saturn S car ATF change - the transmission has a drainplug and spin-on oilfilter.
YUL9ScFlN2fx8cSmSEJRIIFHgyhuxwhxyeci5YWgtKOmfYDxWGL66oLnXTxmTy1W
