TucoRamirez
TucoRamirez New Reader
10/22/09 5:52 p.m.
So I started out slowly on Saturday afternoon on what I though would be a days' work on my 97 lt1 camaro. I was installing a new water pump, distributor cap/rotor, igntition coil, spark plugs and wires. It's now Thursday. My arms and hands look like I tried to perform a rectal exam on a porcupine. I have small hands and it was still a tight squeze and lots of figureing out different approaches. The old plugs looked ok, but I set out to get the job done. And done it is. It fired right up Wednesday evening. Great, except I accidentily poked a hole in the radiator.
There are a lot of cute ladies on public transit. I'm getting a lot of exercise. I like walking to the parts place looking like an oil soaked zombie. The fun is almost over however. I'm borrowing the wench's wagon tomorrow and will get the radiator repaired on my way to work. Anyone else dealt with Lt1 plug changes?
Feedyurhed
Feedyurhed HalfDork
10/22/09 6:57 p.m.
No LT1 experience but I remember the old Buick turbo V6. The turbo plumbing ran along one one bank of plugs so you had to access them from underneath the car and go up. Needless to say didn't do that often. Engineers and designers should be forced to work on the cars they create.
Soma007
Soma007 New Reader
10/22/09 6:59 p.m.
Ahh yes, you should have asked before you started. Maybe I could have saved you a little grief.
They changed a bit over the years but on my '93 TA you removed the Y-pipe in the exhaust, the alternator, and the starter you can get most of the tricky ones from underneath. Sounds like a PITA but they all come off fairly easy and give you lots more room to work. I forget which one (Cyl 6 or 8) on the passenger side I would actually just sit on the radiator support to reach it from above.
Congratulations on getting it done though. If you can do plugs on a LT1 F-Body you can do just about anything on a car! :D
TucoRamirez
10/22/09 7:16 p.m.
Thanks for the compliment. I yanked the alternator and unbolted & moved the starter. I have dual cats, so I'd have to unbolt those along with the y-pipe. I really should have done that since the last time I had them off, I didn't have any anti-sieze to put back on the bolts. Next project. And I got very intimate with the top of the engine.
I also noticed some of the wiring connectors are made of peanut brittle, yet the wiring brackets are made of some unbreakable super plastic. Lots of fun memories.
TucoRamirez
10/22/09 7:18 p.m.
Feedyurhed wrote: Engineers and designers should be forced to work on the cars they create.
Yes they should.
slefain
slefain Dork
10/22/09 7:22 p.m.
The #8 spark plug on my Camaro was the factory unit. I never changed it, and I doubt anyone did after me.
Tom_Spangler
Tom_Spangler Reader
10/22/09 8:03 p.m.
slefain wrote: The #8 spark plug on my Camaro was the factory unit. I never changed it, and I doubt anyone did after me.
That's the front passenger's side one, right? That was by far the hardest one to get. It was ~8 years ago that I did mine, and it was a major PITA, but not the worst job I've ever done on a car. I think installing an SN95 brake booster in a Fox Mustang holds that honor....
Soma007
Soma007 New Reader
10/22/09 8:11 p.m.
That's #2 which is fairly doable if you pull the alternator and it's little bracket.
8 is the last one on the passenger side bank. You actually get decent access on it from underneath if you pull the Y pipe and the starter.
Vettedrmr
Vettedrmr New Reader
10/22/09 9:26 p.m.
Having owned a '94 Z28 since '99 and 210,xxx miles on the odo, I can truly understand the OP's misery. Changing plugs is a piece of cake compared to re-routing the plug wires. First time I changed the plugs and wires right after I bought the car it took me 1.5 hours to swap the plugs, but 7+ hours to change the wires.
Fortunately those wires are still fine after all this time.
Congrats on not burning the car to the ground!
Have a good one, Mike
2002maniac
2002maniac Reader
10/22/09 9:30 p.m.
TucoRamirez wrote: My arms and hands look like I tried to perform a rectal exam on a porcupine.
I thought only BMW's had pricks on the inside?
friedgreencorrado
friedgreencorrado Dork
10/22/09 9:38 p.m.
This belongs in the magazine...
DeadSkunk
DeadSkunk New Reader
10/22/09 10:18 p.m.
I remember seeing a buddy of mine, who ran a Texaco station, charge plug changes by the hour on 428 Cougars. If you wanted the regular flat rate he'd make you sign off on torching a hole in the left inner fender to get at two plugs !! V8 Chevy Monzas were also on his hit list. I think you had to lift the motor on those.
Ian F
Ian F HalfDork
10/23/09 9:13 a.m.
Damn... and I thought changing the plugs in my old '90 Ford van was bad... ...you guys have my sympathy...
iceracer
iceracer HalfDork
10/23/09 9:22 a.m.
Yes they should.
That was always my favorite statement. Repeated many times over the years.
Strizzo
Strizzo SuperDork
10/23/09 10:26 a.m.
similar to the turbo plumbing gripe, the egr pipe on my truck ran right over the top of the passenger side bank of the v6. two inches either side and there would be noooo problem
Woody
Woody SuperDork
10/23/09 12:54 p.m.
I used to work for a yacht maintenance company. Try changing the outer plugs on a twin engined boat. They were most often found to be a different brand than the inner ones and likely the ones that came from the factory. As a bonus, this generally took place when we were winterizing the boats after they had been pulled from the water in November, so it was usually 35 degrees, damp and windy, even down in the bilge.
amg_rx7
amg_rx7 Reader
10/23/09 1:30 p.m.
Wow. I'm glad I own a 3rd gen RX7. The hardest thing we ever have to deal with is the tricky vacuum system.
44Dwarf
44Dwarf HalfDork
10/23/09 1:31 p.m.
None of you ever had a V8 Vega / Monza did you?........
The quickest way to change the plugs was to pull the motor mounts and jack the motor to the firewall, use 2 universals and three extentions. Did it twice then at the drag i saw another car like mine....Smart guy used a hole saw to the inner fenderwell. I did mine the next day.
My Monza was a factory 151 car but i stuffed a 350 in to it. Oh what fun till the timing chain let go..
44
GTwannaB
GTwannaB New Reader
10/23/09 1:43 p.m.
V8 Monza - unbolt the motor mounts and bottle jack to the block. That was a strange car, the gas pedal was harder to push down than the brake pedal. Not a very balanced vehicle.
Capt Slow
Capt Slow Reader
10/23/09 2:39 p.m.
I had a friend ask me for help in chaning the spark plugs on his early 80s 300zx. Being ignorant of what that car looked like under the hood I gave him a ration of E36 M3 for not being able to handle such a "simple" job.
He got the last laugh when he popped the hood... The enitire intake manifold needed to be removed to get to the plugs...
andrave
andrave HalfDork
10/23/09 2:48 p.m.
a guy I used to work with had a bently coupe with the W 12. Engine removal is required for spark plug replacement.
No joke.
DirtyBird222
DirtyBird222 Dork
10/23/09 2:55 p.m.
It's usually a good time to do headers as well when you do spark plugs on any 4th gen f-body. That's how I've always done it. Then changing the plugs and wires (especially on an LT1) is way easier because you'll do it so much more when the headers start burning up everything in their path :)
rjones33
rjones33 New Reader
10/23/09 2:57 p.m.
awesome.
Giant Purple Snorklewacker
Giant Purple Snorklewacker Dork
10/23/09 3:04 p.m.
Sometimes its just easier to pull the motor or get a different car.
TucoRamirez
10/23/09 3:50 p.m.
I usually blame Canada & Canadians for any problems with this car they made. Detroit gets the heat for the design though.
I didn't have to move the engine, so it coulda been worse.
cSWRH2Y6PqcqGPFIdzASqchcxvLKIfXEAm3nlN8RgQjTUHxpwRTnKSCGYH3RUGQf
