Toyman01
Toyman01 SuperDork
3/11/12 6:45 p.m.
Now to save up the scratch for new tires.
I guess it's time to start the body work too. Damn that's a lot of sheet metal.
Ranger50
Ranger50 SuperDork
3/11/12 6:53 p.m.
Sweet.
The longer the board the better you will be.
Javelin
Javelin SuperDork
3/11/12 7:12 p.m.
Ranger50 wrote: Sweet. The longer the board the better you will be.
Try stringing a roll of sand paper on a concrete building and just driving back-and-forth...
Toyman01
Toyman01 SuperDork
3/11/12 7:15 p.m.
Ranger50 wrote: The longer the board the better you will be.
That's a fact.
I think there are close to 70 of these studs to be removed.
I'm not looking forward to it. Much sanding will be involved.
Toyman01
Toyman01 SuperDork
3/11/12 7:16 p.m.
In reply to Javelin:
That's a good one.
pinchvalve
pinchvalve SuperDork
3/11/12 7:28 p.m.
BELT SANDER?
JThw8
JThw8 SuperDork
3/11/12 7:41 p.m.
If I can make you feel at all better about it, be glad they used the stud system. You just need to grind those off and sand. Imagine if they used the standard push in connectors and all the holes you'd have to weld shut.
Toyman01
Toyman01 SuperDork
3/11/12 7:47 p.m.
In reply to JThw8:
There are a few holes to fix too.
As for sanding, my father has one of these:
He's used it on his boat with good result. I'm thinking about trying it.
Graefin10
Graefin10 Dork
3/11/12 7:58 p.m.
Toyman01 wrote: In reply to JThw8: There are a few holes to fix too. As for sanding, my father has one of these: He's used it on his boat with good result. I'm thinking about trying it.
Yeah, these things work great. Use a lot of air though, and needless to say wear ear protection. No, use ear plugs and muffs. After you prime it with sanding primer then use a long hand board. Take your time and watch for the low spots. Using alternate colors of primer helps a lot. You can't miss your low spots that way. You'll be proud to show off that much straight sheet metal. WTH, paint it black.
Toyman01
Toyman01 SuperDork
3/11/12 8:47 p.m.
In reply to Graefin10:
My spray skills aren't up to black yet. I have a hard enough time with white.
Ranger50
Ranger50 SuperDork
3/11/12 8:51 p.m.
LMAO... Good one.
kcfeDxh9MhRyJXzIoIV5Y4oDKVCEuOF6JdTSvlYJG8HanEw2A1SOsaxyijrCxeN8
