Gearheadotaku
Gearheadotaku UltimaDork
12/20/19 6:36 p.m.
 So I'm working on a '96  Nissan truck that's rattling like a diesel. The timing chain has been changed with the guides etc. (not by me) No change in the noise. Also has a ton of blow by. Compression is good, 160+ across the board. No change in noise when disconnecting  spark plug wires one at a time to change piston load. 200,000+ miles. No smoke out the tail pipe. Truck actually runs fine and idles smoothly aside from the noise.  Not sure about the rocker arms with their little hydraulic lifter like deals on the ends.
Ideas?
b13990
b13990 Reader
12/20/19 6:50 p.m.
It's extremely cold right now. How does it sound in June?
Javelin
Javelin MegaDork
12/20/19 7:15 p.m.
Rattling like a rod bearing or like hydraulic lifters not pumping up?
Patientzero
Patientzero Reader
12/20/19 7:29 p.m.
My vote would be ring land.
iceracer
iceracer UltimaDork
12/20/19 7:38 p.m.
piston slap ?
Streetwiseguy
Streetwiseguy MegaDork
12/20/19 8:08 p.m.
The blowby suggests a piston problem, or valve guided totally pooched.  You said 200,000 miles, right?  Ain't worth fixing unless you do it right, and that probably involves a hefty machine shop bill.
ShawnG
ShawnG PowerDork
12/20/19 11:17 p.m.
"No good cryin' kid, the whole thing's f-ed and it has to come apart" - one of my mentors.
Gearheadotaku
12/21/19 8:15 a.m.
More like lifters. Oil pressure is good and plenty of oil upstairs. Engine is clean inside, not all sludged up.
nk9iRMh82OF84ezsMd50uEgDOVwYTbS7sfOVNbyVodOqRvA5jNio5YnMmqdh3GFQ
