KB are you welding the tubes while they are on your wooden jig? If so how do you avoid issues with fire?
Thanks in advance for insight.
Right, I don't actually weld on the table; the closest I ever get is maybe 1/2" when the sides of the bottom tubes are being tacked. Then the entire floor is removed, flipped over, and finish welded. Also, the table surface is MDF - kind of like compressed wood "lint.". It blackens and there's a bit of smoke, but it never catches fire. Keep in mind I'm TIG welder with argon shielding gas that inhibits combustion. If it was gas-welding it could be a different story.
And yes I do have fire extinguishers
Welcome back (sort of) Kurt!
Looks like you're making progress more often than just on the weekends now
I'm moving slow on my TVR project. I did get some motivation with the car being featured in Hot Rod's Project Garage section in the May issue. Trying to make progress at the moment is a little difficult -- having hip problems and am scheduled for surgery in a couple weeks. Hoping I can get a few days work in on the car as I'm "recuperating".....
Looking at your "clean sheet" approach with Midlana makes me a little envious and reminds me of the challenges you faced with Kimini -- it's harder to package things in an existing envelope as opposed to doing a purpose built car starting with the basic frame and chassis and building that up and around where your engine/suspension/etc, components will be located.
As you found out with Kimini, it sure is hard packing a lot of systems into a car with a set track, wheelbase, etc....
Thanks as always for the inspiration -- don't know if I'll ever complete a car like Midlana, but I always learn something from your efforts!
-jeff d
Thanks for taking time to answer the question about welding in the jig One of my biggest issues was the thought of creating mega heavy metal jigs. This solution is a good one.
Welding heat causes distortion, causing tubes to contract more than they expand, pulling angles inward with tremendous force - it pretty much laughs at any table it's bolted to. It's kind of like dancing with an elephant. All you can do is try and manage which way it'll move next, but nothing will actually stop it.
Things are moving along. Over the last month a lot was accomplished thanks to my wife being on a business trip and me having a long vacation. The fuel system, cooling system, and the basic frame are done and fully welded. Currently working on suspension arm fixtures - which take a ton of work in the form of many drawings!
Transverse engine (ala Kimini or Ariel Atom) or longitudinal?
Never mind, answered my own question - transverse. Makes more sense that way.
It's too hard to ignore all the FWD transverse drivetrains sitting around, just looking for an application. Also, being transverse it consumes much less fore-aft space and keeps the car looking (slightly) less goofy.
Finished fabricating the 321 stainless exhaust - and yes, that's a turbo ;). Electrical is underway:
Freaking awesome as always. What kind of motor is that? My engine ID skills are failing me. It's a Honda product, but which one I cannot tell.
It's what the Honda-Kids call a "Frank" (short for Frankenstein.) The block is a K24A1 from a 2.4 liter Honda CRV, the head is from an Acura TSX, and the transmission is from a base Acura RSX. It's designed to handle 400 hp on pump gas, but I suspect the boost will be turned way down most of the time...
I can already say that going berzerk on the engine was a mistake this early-on. But after it's done I think I won't lament it too much
Pardon my ignorance, but I see three pipes combining before the muffler - the turbo outlet, the wastegate and? A second wastegate?
Very nice work. I was getting used to you as an internet pontificator. I forgot that you're a fine fabricator!
Pontificator... I'll add that to the other labels I got stuck with, including, "Suspension Nazi", but not in a nice way...
More like a mid-engine Locost (Lotus Super 7 clone.) It uses Super 7 fenders and nose cone. Here's a side pic:
kreb wrote: Pardon my ignorance, but I see three pipes combining before the muffler - the turbo outlet, the wastegate and? A second wastegate?
Yes. It's what's called a twin-scroll turbo, where cylinders 1,4 go to one side and 2,3 go to the other. Supposed to give about 6% more power and minimize lag.
And before people give me grief that a turbo may very well be slower in terms of lap time, don't forget that we build our cars, really, for only one reason: to have fun. If it results in being a bit slower, eh, a plastic trophy just isn't that important. I've never owned a turbo car and want to see what they're like.
There's a bunch more pictures on the Midlana website, check out the build diary.
Oh, and a turbo surely must help my chances at getting into GRM a second time - I hope!
That's nice fabrication. Reading some of your website, it appears you're actually quite the engineer too. I am just like that... in my dreams. No, literally, I have dreams about doing such things, except for in my dreams there is occasionally this strange otter, and my engineering and fabrication skills are still not as good as yours are in real life.
Never underestimate what you can do. I was an electrical engineer, now I do sw, but I've always liked to make stuff. None of that has anything to do with cars exactly, so I think a lot of "potential energy" is wasting away in this country watching TV each night. Not you necessarily, but in general. Hey, once the book's done, see if it's something you might want to attempt; it'll step through the entire build. And, the book's not a fantasy - the manuscript's currently at 281 pages. Since the car and book are being created in parallel, it (the book) will be out about a month after the car's first trackday event.
