Toot
Toot New Reader
8/21/21 6:43 p.m.
Has anyone worked on a lancia zegato before
TurnerX19
TurnerX19 UltraDork
8/21/21 6:53 p.m.
Which Zagato Lancia? The Beta Zagato, no I have not, and don't wish too, although the power train is familiar. I have worked a lot on a Lancia Appia Zagato. That is a real Lancia!
Toot
Toot New Reader
8/21/21 9:22 p.m.
It is the 1981 beta.   The car is rust free but been in storage for 15+ years.  I know it needs a water pump just wondering what else should be replaced and how difficult it is going to be. Btw I'm doing this for my 75yr old neighbor for one last ride down memory lane.
Stampie
Stampie MegaDork
8/21/21 9:32 p.m.
Any car in storage for 15+ years needs a lot more than a water pump much less an early 80's Italian car.
BoxheadTim
BoxheadTim MegaDork
8/22/21 6:57 a.m.
In reply to Toot :
Timing belt, IIRC these are interference engines. I wouldn't even try to turn it over otherwise.
Any rubber parts like fuel lines might also be suspect.
porschenut
porschenut Reader
8/22/21 7:41 a.m.
Parts will be tough, but there are specialty shops.  Wiring in these cars was crap. Engine was a fiat 1800 turned sideways.  Underpowered. You are a good egg to try helping though.
ddavidv
ddavidv UltimaDork
8/22/21 8:06 a.m.
I recommend going here: https://mirafiori.com/forum/
Those things are miserable to work on, unfortunately, which is why I never owned one despite loving most anything with that Lampredi engine. Timing belt is a must. 1981 should be EFI. I suspect they have the same ignition as the Fiat, so the pickup unit will probably need replaced. The wires always corrode where they enter the distributor. Fairly inexpensive part. Electrical issues are 99% dirty contacts/bad grounds. Shifters can get sloppy when the bushings go bad. Not sure if you can still buy them or not.
Lancia Betas get zero respect from the Lancia crowd. You'll need to hang with the Fiat people for respect and assistance.
porschenut
porschenut Reader
8/22/21 10:42 a.m.
Had a Beta Coupe, one of the first ones off the boat.  Also one of the few cars I never wished for again.  Did get me across the country 3 times and was a great handling car for FWD but a nightmare to keep running sometimes.  A broken ground wire from the battery to chassis stranded me more than once, wires corroded inside the insulation in the MIDDLE of the length.
BoxheadTim
BoxheadTim MegaDork
8/22/21 11:00 a.m.
Midwest Bayless has parts for Betas: https://www.midwest-bayless.com/lancia-beta-0-parts.aspx
wspohn
wspohn SuperDork
8/22/21 11:33 a.m.
One example of how old can be better than new.
I'd be reluctant to spin an engine that had been sitting for a decade or two if it used a timing belt, but wouldn't think twice about doing it with a proper timing chain in there (although I'd turn it first by hand to be sure it was free).
obsolete
obsolete Reader
8/22/21 1:30 p.m.
In reply to wspohn :
Lots of modern cars with VVT have moved from belts back to chains. Old is new again.
zagato2
zagato2 New Reader
5/13/25 10:51 a.m.
In reply to Toot :
My uncle is in the same boat, rust is not a friend, any chance your neighbor still has his?
Tk8398
Tk8398 HalfDork
5/13/25 2:59 p.m.
In general timing belt, fuel lines, coolant hoses (at least check and replace if you can), and change all the fluids.  Beyond that it's anyone's guess.
ddavidv
ddavidv UltimaDork
5/14/25 7:59 a.m.
Zombie thread, risen from the dead.
BTW if anyone is looking for a Beta Zagato (or 3) I know a guy who has a few sitting in indoor storage. And pretty much any other Fiat or Lancia you could hope to own. He's starting to pare down his collection.
zagato2
zagato2 New Reader
5/14/25 11:14 a.m.
Three? Did they ship that many over? If they're in good condition please reach out to me, thanks! Yeah, this one's fuel lines, gas tank, grounding wires and many others are in various states of degradation.
cunzatu
cunzatu New Reader
5/14/25 11:24 a.m.
In reply to ddavidv : Been looking for a Zagato for awhile. Please contact me.
lCryLnKT6INOceMtSmRWIL6lGhNABTiwjPZv48mz1ASVDKepjMwA9c4cnmbQYcJu
