Incircles019
Incircles019 New Reader
7/22/18 11:17 a.m.
I have an older John Deere lawn tractor K series 14hp that won’t start. I have fuel pressure and spark. I had it running yesterday but the rpms were low and wouldn’t run under load. Any thoughts
7/22/18 11:24 a.m.
How long since it ran?  Sounds like a gummy jet.
68TR250
68TR250 Reader
7/22/18 11:37 a.m.
Bad gas?  Mouse nest in the exhaust pipe?
Incircles019
7/22/18 11:40 a.m.
I put a new carb on it thinking it was gumbed up. The gas is fresh
Indy-Barely Functional-Guy
Indy-Barely Functional-Guy UltraDork
7/22/18 11:53 a.m.
Governor spring fall off or broken?
Fouled up plug?
Fletch1
Fletch1 Dork
7/22/18 12:52 p.m.
I've heard faulty gas caps could prevent starting.  Also, parking brake switch or seat safety kill switch.  A few weeks ago, mine starting bogging down about every 20 seconds for a brief few seconds while mowing.  I ended finding out that the vent tube was clogged.  It runs from the carb down through a hole in the frame and hangs there.  I cleaned it and runs fine now.  Not sure if that could also prevent starting.
68TR250
68TR250 Reader
7/22/18 2:27 p.m.
Is it turning over?  Turning over fast or barely turning over?  Gas flow good to the carb?  Good strong spark?  Muffler blocked?  If the muffler has rusted pieces inside it could be closed off  ( Broken baffle ) that could prevent it from starting.
Incircles019
7/22/18 6:29 p.m.
It’s turning fast like there’s no resistance
7/22/18 6:59 p.m.
That sounds like a lack of compression.  Probably wiped out a cam lobe.
Or maybe ventilated the block? Maybe broke the connecting rod?
fasted58
fasted58 MegaDork
7/22/18 7:05 p.m.
What engine?
B&S Intek engines can have an issue w/ valve seat inserts loosening or popping out = no compression.
68TR250
68TR250 Reader
7/22/18 7:51 p.m.
Check the compression.   Is it a Kohler pr Kawasaki?   The KW engines have been known to shear the woodruff key.   It should have compression.  Watching a Youtube video a push mower showed 110 PSI.  If your motor has a low compression reading, it may be time to find a new motor.   Your results may vary.
fasted58
fasted58 MegaDork
7/22/18 8:13 p.m.
Had an odd issue w/ my Kohler Command. Cranked like a champ, battery tested 12+ volts, good fuel, spark and compression. Started, ran and drove. While cutting though engine would lose power, chug and eventually stop.
Assuming battery was good, running w/ electric PTO engaged the fuel cutoff solenoid (anti-backfire) read less than 7 volts and would starve the fuel bowl. Battery marginal, replaced battery w/ new and all was good again.
I've also had the blocked gas cap vent and old fuel hose degrading from inside and restricting orifices among other loss of power and running issues.
0.02
Incircles019
7/23/18 5:01 p.m.
I cranked the engine over today seemed like it wanted to start. While cranking I took out the dipstick and up with oil shooting in the air.
I’m thinking I have bad bad rings.
Thanks to everyone for your input
7/23/18 5:13 p.m.
Overhead valve engine? Pull the valve cover, inspect.  Then crank and verify valves and springs are compressing as they should.
fasted58
fasted58 MegaDork
7/23/18 5:17 p.m.
and check/ adjust valve clearance
npFqPlIULC9ghqveOp4UWBkIENG7Cpa6BGM3BPpLvnnZ6ZmqcW3DqzttZ2gH6GY2
