My 318ti project has a leaky oil drain plug. It was an M12 bolt, but the previous owner threw in a 1/2" bolt once he stripped it out. It still leaks. I'm thinking of getting some teflon tape and another oversize drain plug with a piggyback plug to solve the issue. Then I can do all my drains from the piggyback plug.
![](http://contentinfo.autozone.com/znetcs/product-info/en/US/drm/090-035.1/image/3/)
What says GRM'ers?
Looking for a cheap but permanent fix.
We'd usually go 1 size bigger, if that didn't/couldn't work, then we'd go piggy back, if that didn't work we tried to sell an oil pan.
Piggy back usually worked though.
In reply to bigdaddylee82:
You'd sell some poor bastard your leaky oil pan? ![](/media/img/icons/smilies/googly-18.png)
Steel or aluminum pan? Can you weld, if so with what equipment?
Aluminum pan. Can't weld.
I'm really hoping that a 1/2" oversize piggyback plug will work with my problem. Should I add the teflon tape or threadlocker to the oversize plug to make sure there are no more leaks?
In reply to MINIzguy:
The piggy backs we used, were self tapping, and had some kind of rubber/plastic gasket between the oil pan and flange of the bolt/plug, no other sealing material needed.
How about heli-coil? It's what we usually do. Drill, tap, clean, heli-coil, and rock on.
1/4 or 3/8 pipe plug? Tap pan and use shop vacuum to keep chips out of pan.
You could drill & tap the plug for a piggyback.
I would try running an original-size tap into the hole to clean up what's left of the threads, and then use a new drain bolt (with all its original thread metal intact) and sealing ring. The sealing effect comes from the sealing ring being compressed, not from the threads, as in a pipe thread.
If that doesn't work, you can still go oversize.
I'll keep the Helicoil in mind.
But I am worried as I don't know what size to use, whether it be re-tapping, oversize or Helicoil.
Originally, it was a M12. Now I have a 1/2" bolt (12.7mm) that I don't know if it is oversized or not. The only markings on the bolt is 1/2" with nothing stating OS from what I recall.
What should I re-tap with? 1/2" again? I can't go back to M12 as it would be too small.
Id think .7 mm oversize is about how big the helicoil bore would be. So you'd not be removing much material that hasn't already been.
Watching some YouTube videos on a Helicoil, I would have to drill out the hole, tap and then helicoil, right? Wouldn't that now make my hole even bigger than 1/2"? Or would a 1/2" helicoil account for the bigger size so I don't have to worry?
And how would I keep my shavings out of my oil pan the best I can? Run a magnet after drilling, and always run a magnetic oil plug?
You would helicoil at m12 if the hole isn't too big for it already, and I dont think it is, drill diameter for a m12x1.75 helicoil is 12.5mm, You'd have a pretty smooth hole running a drill that big through a 1/2" threaded hole. In some cases like this you can get away with just running the helicoil tap through the damaged oversize threads, but I dont recommended that.
And yes, drill, run in the coil tap, spin in the coil, reach in and break off the end, flush it out by dumping a quart or two of cheap oil, or maybe diesel fuel chased with oil, through the engine, screw in a standard plug with new fiber washer, torque to spec, done.
I'm understanding it now. Tap size for my 1/2" is 29/64" which is less than 12mm. So a M12x1.75 helicoil tap is 12.5mm so I would be peachy perfect. Awesome! Thanks for the help guys!
