phaze1todd
phaze1todd HalfDork
12/19/13 7:07 a.m.
Been eyeing this up for a little while. Hasn't moved in months.
silver automatic 68,000 miles
details: A stunning low mileage example of Porsche 'top dog' twin turbo SUV.
Interior and exterior is outstanding condition 6 piston Brembo calipers Custom Rial Wheels (Made in Germany) with high performance all season tires Navigation Supple Leather Heated front AND rear seats Heated steering wheel Air suspension Xenon Lights BOSE stereo with single and 6 disc CD changer Power sunroof Alcantara suede headliner Rear heat Hard to find these with low miles and in such great condition. Have all keys and manuals. No accidents, non smoker. Everything works as designed.
It's in the $25,000 range.
Gearheadotaku
Gearheadotaku UberDork
12/19/13 7:09 a.m.
Check to see if the coolant tubes under the intake have been updated. new ones are aluminum. Check carrier bearing on rear driveshaft. If bad, entire shaft needs to be replaced.
2002maniac
2002maniac HalfDork
12/19/13 9:02 a.m.
Check the price of replacement tires.
phaze1todd
phaze1todd HalfDork
12/19/13 9:17 a.m.
2002maniac wrote: Check the price of replacement tires.
Not bad actually. From $600 to $1800 for all corners and good rated name brands.
mndsm
mndsm UltimaDork
12/19/13 9:18 a.m.
That's not terrible at all. I have a gbar into the *specs on my ms3....
Maroon92
Maroon92 MegaDork
12/19/13 9:57 a.m.
There is a rather expensive computer control module that goes bad in the 4 wheel drive unit. I think it's a couple grand.
The rear hatch shocks fail.
The coolant pipes aren't too difficult to do. However, the Turbo has a separate piece that goes down the back of the engine between the left bank and the firewall that is difficult to replace. It is a pipe that feeds the turbochargers with coolant.
(they are all automatics (tiptronics)...)
Conquest351
Conquest351 UltraDork
12/19/13 9:59 a.m.
Just buy it! Bigger turbos and intercoolers and win at everything!
phaze1todd
phaze1todd HalfDork
12/20/13 7:39 a.m.
Seller said coolant pipes weren't done yet, but seal on driveshaft bearing looks new.
He also has an S with 118k miles with new aluminum coolant pipes and carrier bearing for $13k. Is mileage too high. Is this where the nickle and dimeing begins?
Maroon92
Maroon92 MegaDork
12/20/13 8:13 a.m.
Just be aware that, for the most part, Porsche does not rebuild those engines. If you spin a bearing or they just wear too much, they'll just say it's best to install a 16K+ crate engine.
Also, the S is nowhere near as fun as the Turbo.
plance1
plance1 Dork
12/20/13 8:24 a.m.
I've seen a couple of these in the $15k range.
LisDRNPBydA1n84c7yUFhEaPw0M23Ml7C0AyRnndZAGXMrNvio5gfqHmsDoYzVH5
