Anything note worthy? It's a So-cal car it's entire life. 99' w/ 109k on the clock, 350, 4x4, looks brand new inside and out (owned by a grandma)
The suspension and leafsprings look new. The frame and rockers has some surface rust, but nothing I can see looks remotely bad.
I'm getting it for a tow pig/people mover. The eight seater is nice!
Nothing on it's broken, but what should I do to keep it that way? The only thing that needs looked after immediately (as far as I can tell) is the powersteering pump acted funny right when it started, and then was normal from there after. He said it had been doing it for a while.
Be sure to keep it running cool and watch for any coolant loss. The Vortec is a nice bit of kit but they eventually develop intake manifold gasket leaks. Catch it early, pull and reseal the intake, everything is fine. Let it go and ask for trouble, something to do with cracks in the cylinder heads. Service the diff(s). Enjoy. They are really pretty solid and even though the newer models are even nicer inside, they aren't a bad place to pass the miles.
My '99 has 239,700 on the clock now. Tow in D not OD.
The brakes are pretty puny by modern standards and as old as they are fresh pads and fluid is a good idea.
In reply to conesare2seconds:
Will do, thanks!
In reply to KyAllroad:
Pad recommendations? I literally know nothing of trucks...
A lot of GM trucks of that era have hub-bearings start failing not long after 100k, ABS light, or wonky ABS action is the warning. Get good bearings.
I use whatever advancezonereilly offers in premium gold lifetime replacement. That way when (not if) a slider sticks or something gets wonky I get a new set for free.
Rears are drums BTW. Good idea to do a full rebuild now with brake cylinders and adjustors. Had one of each fail and been annoyed mid trip. Such cheap parts to buy, and if you have it apart already not much more effort.
OH!! I forgot AC Delco ONLY on these motors, you wouldn't think it would matter but it really really does.
+1 on the towing in D only. Tranny is not the most durable but I towed fine with my '97 after smoking the 1st trans. Guy who rebuilt it said NEVER drive it in OD with a trailer on the back. I also added a temp gauge to keep an eye on it that way if it got too warm I could give it a rest, but never needed to. Mine went 240k miles in New England and was getting too rotted to keep driving safely after 13 years of salt.
Looks really nice! I just bought a '98 K1500, which is very, very similar.
Headlight circuitry is a weak point as there aren't any relays. Wire some in so that the headlight switch and multifunction switch don't have to take the load, or they will eventually fail. Both were actually bad on mine.
Front steering linkage tends to wear - a new pitman arm, idler arm, and idler arm mount is often enough to tighten it back up, and is a ~4 hour job.
That truck (and mine) is new enough to have EVO steering, which has a PWM valve that controls effort. They work well when working right, but they don't always work right. There are eliminator kits out there, or you can replace the valve for a bit more money.
New fluid really helped the brakes on mine. Still working on what pads to get. There are tutorials on upgrading to brakes from a newer model if you plan on towing/hauling a lot.
Vortec engine is mostly solid, but the heads are a lighter iron casting and if overheated, will crack between the 2-4 and 3-5 cylinders on up through the valve seats. Don't overheat it and this won't be a problem. Colder thermostats significantly hurt mileage, but due to the old american nature of these, many have 160 or 180 degree stats. It should have a 195.
Intake manifold gaskets can leak, showing up as a vacuum leak for the upper intake or oil/coolant leak typically down the rear of the block if it's the lower intake. Neither are that hard to replace.
Vortecs use the 'spider' injection with a central electronic fuel distributor. Strange running issues can often be traced to the hard lines cracking and leaking into the manifold or injectors that are sticking somewhat. Replacements are available.
Bolt pattern is the same as every other 4x4 6 lug chevy, so takeoff wheels from a newer truck are readily available and can significantly improve the aesthetics of the truck.
Here's mine with 2010 Yukon wheels:
I think they're great trucks. Definitely more truck-y than the modern stuff, but they are built well and can last forever. Many consider the GMT400s like this to be the high point of GM trucks, since the next generation more rust and electronic issues and further generations move away from being truck-like more and more.
Awesome info all around!
AC Delco? For what parts? I'm sorry, not familiar with the brand (part?).
In reply to gearheadE30:
Awesome info! Big brakes would be nice as long as the ABS doesn't mind. I'll do the fluid asap, I'm sure it hasn't been touched. That truck looks great btw. I do like the newer rims. Good to have options.
Does anyone use a specific forum? I'm planning on running through all the preventative maintenance mentioned here. The budget allows since I got this instead of a newer truck.
In reply to accordionfolder:
I haven't read up on it enough, but I don't think ABS cares at all.
GMT400 and FullSizeChevy (FSC) both seem to have a lot of good information sprinkled with a solid dose of country ingenuity. Seems like the owner's groups for the GMT400 trucks are pretty enthusiastic about them, and there's so many out there that most issues are well documented.
