Trackmouse
Trackmouse SuperDork
9/6/17 12:57 a.m.
https://bend.craigslist.org/cto/d/2004-chevy-aveo/6291844218.html
Or should I say "learn me: the brave little toaster!" I know these are bad, but how bad? Should I run? Is it "no avail for the aveo"?
Trackmouse
9/6/17 8:39 p.m.
Man, this must be one boring topic...
JeffHarbert
JeffHarbert HalfDork
9/6/17 8:44 p.m.
Not so much boring as penalizing. It's better than walking. Slightly. All of the personality of curdled milk without the zingy taste.
Robbie
Robbie PowerDork
9/6/17 8:49 p.m.
I bet it's a good for taking off of sweet jumps.
mad_machine
mad_machine MegaDork
9/6/17 9:05 p.m.
can't be worse than the metro
mndsm
mndsm MegaDork
9/6/17 9:19 p.m.
In reply to mad_machine :
I see more running metros. From what I know, Daewoo gave these things all the transmission functionality of sticking a fork in a toaster. Replacing them with the tires was not unheard of.
rslifkin
rslifkin SuperDork
9/6/17 9:23 p.m.
From what I remember of them, it's not uncommon for the timing belt to snap and kill the engine before 60k miles...
Trackmouse
9/7/17 1:19 a.m.
Yowzas. Avoid like a hurricane.
ebonyandivory
ebonyandivory UberDork
9/7/17 7:02 a.m.
In reply to Trackmouse :
I've asked this very question. I ever bought one of that tells you anything. Sure doesn't stop the temptation though!
https://grassrootsmotorsports.com/forum/grm/so-whats-up-with-aveos-makes-a-yugo-look-like-a-civic/79632/page1/
maschinenbau
maschinenbau HalfDork
9/7/17 8:00 a.m.
I drove one for a summer. It was my cranky grandpa's brand new zero-option sedan, 5-speed, no A/C, power nothing, only AM/FM radio. MSRP was like $8,500! Yet it struggled to hit 30 mpg. I get 29-30 in my Saturn Astra without trying, and that car is leaps and bounds higher quality. Yes that's right - an Aveo will make a re-badged bankruptcy era Vauxhall feel like a BMW. My standards for cars were set this low because of an Aveo.
Didn't have it long enough to speak to maintenance. Didn't need to.
Buy something else. Anything else.
MadScientistMatt
MadScientistMatt PowerDork
9/7/17 8:03 a.m.
They can be rather amusing to thrash on an autocross course as well, as they turn in pretty quickly. Not necessarily fast around one, but entertaining in a drive it like you stole it way. I did that at the GM Auto Show in Motion... but there may have been a reason the course they set up didn't let you test an Aveo at anything like highway speed.
Sky_Render
Sky_Render SuperDork
9/7/17 8:23 a.m.
I've had Aveos as rental cars when I used to travel a lot.
I would choose literally any other vehicle over an Aveo.
I distinctly remember needing to turn off the A/C before attempting to merge into Houston traffic.
Bobzilla
Bobzilla MegaDork
9/7/17 9:41 a.m.
CO-WORKER has one. 09 with jus shy 100k miles. It's a pile. A complete pile. Cooling systmen has had major work 3 times in 3 years. Seems to love chucking T-stats and sensors. Eats tire. I finally had it in the garage and put the plates on and the rear beam is tweaked.
Just.... no.
mndsm
mndsm MegaDork
9/7/17 9:51 a.m.
Is this the second coming of the freelander? Another car not even grm will defend?
rob_lewis
rob_lewis UltraDork
9/7/17 11:52 a.m.
I know zero about them.  But, from the sounds of this board, they are incredibly slow, which I would take as you could drive the wee out of it and never get into trouble (provided it doesn't fall apart).  At that price range, you have lots of room to have fun with it and make "improvements".  Would sticky tires and wider rims help?  4x100 rims are as common as dirt, so you could probably slap some former ricer rims on it and have fun.  Maybe figure out how to put better shocks/springs/bars to wake up the handling?  A DIY cold air kit?  Mock up some type of turbo on it?  Granted, anything you did would probably lower the value, but it may not matter if you're just looking for a fun little commuter.
While others see a pos, I'd take that as a challenge to see what you could do with it to increase the grins per mile......
-Rob
mndsm
mndsm MegaDork
9/7/17 1:04 p.m.
In reply to rob_lewis :
Hard to lower what is already worthless. You have a point, cutting one up would make you out like 50 bucks.
Robbie
Robbie PowerDork
9/7/17 1:38 p.m.
I like this idea of a challenge. I'd certainly rock this one (even if only a photoshop - I can't tell - it looks cool to me):
Internet says only 2300 ish lbs in stock form, so a motor swap or big turbo should really wake it up.
Bobzilla
Bobzilla MegaDork
9/7/17 2:34 p.m.
-Rob
The hardest part of that equation is there are better starting points out there. The Hy/Kia twins are better in every way. Easier to fix. Not a Daewoo. The engine is a better starting point, the suspension has a better feel, the cars are just made better. I'd find it really hard to waste time on that particular Korean E36 M3box when there are better Korean E36 M3boxes that start where that one would end after mods.
trigun7469
trigun7469 SuperDork
9/7/17 2:34 p.m.
So what if you swapped everything over from a wrecked Cobalt SS?
pointofdeparture
pointofdeparture PowerDork
9/7/17 2:47 p.m.
In reply to trigun7469 :
Platforms are unrelated so with the amount of work you'd put into it, you could put that Cobalt SS stuff into pretty much anything else and come out ahead.
fidelity101
fidelity101 SuperDork
9/7/17 3:17 p.m.
painful fiery death
Streetwiseguy
Streetwiseguy UltimaDork
9/7/17 6:29 p.m.
Junk.  The rear axle is a throw away, and it needs to be thrown away pretty regularly.  The timing belt is made of aged cheddar.  No fun.  No swapability.  Paint falls off.
A bicycle would be better.
Bobzilla
Bobzilla MegaDork
9/7/17 7:45 p.m.
Truth. You'll walk less with the bicycle
chada75
chada75 Reader
9/7/17 8:37 p.m.
In reply to Bobzilla :
And go faster as well.
Vigo UltimaDork
9/7/17 9:00 p.m.
I dunno how bad Daewoos really are since a lot of people here seem to like the Cruze. I just did a cylinder head and timing belt on a Suzuki Forenza (Daewoo) because the Tbelt idler fell apart at 70k (but 10 years old..). I actually liked the motor ok.
I don't have much direct experience with Aveos. I diagnosed a bad PCM on one once. I like the early italian headlight treatment a little bit but find it comically similar to the early Lexus GS front end (which i hate) which may or may not have also been styled by Giugiaro.
I can't really defend the Aveo, and i find something to like about pretty much everything.
vSVlgTirXolZ79aSTJkUkkC7sNre5keevBGbsli7WswAzSInMYAf26Iqkbn3LFPf
