Daeldalus
Daeldalus New Reader
6/8/17 11:14 a.m.
I need to lubricate the locks on my e30. Best thing for the job?
Graphite? Silicone? Something else?
Bonus points: what to use on the latch assembly?
TGMF
TGMF Reader
6/8/17 11:38 a.m.
Door locks- Best stuff I've ever used. https://www.amazon.com/ACDelco-10-4020-Rust-Penetrating-Lubricant/dp/B008I2H55U
Normal flowable grease for the hinges, I liked the 3M product. https://www.amazon.com/3M-08878-Spray-Lube-oz/dp/B0002JLQ8E/ref=sr_1_1?s=automotive&ie=UTF8&qid=1496939877&sr=1-1&keywords=3M+flowable+grease
ssswitch
ssswitch Dork
6/8/17 11:39 a.m.
Be careful with graphite, I used some on my beater Miata's key-bendingly-bad locks a few years ago and ended up with a permanent stain in the cratered single-stage white paint which was not attractive.
6/8/17 11:41 a.m.
Silicone. Graphite, once wet, becomes a gooey ball.
EvanR
EvanR SuperDork
6/8/17 12:06 p.m.
Buy this, and never use anything else on any lock, automotive, commercial, or residential.
source: a very satisfied customer.
dculberson
dculberson PowerDork
6/8/17 1:07 p.m.
No graphite! It's not 1930 anymore.
I use Tri-Flow at work and at home, and it's good stuff.
noddaz
noddaz SuperDork
6/8/17 8:28 p.m.
I have used WD-40 to loosen the locks up. And later have followed up with with oil I could force past the trap door. Which is usually some sort of penetrating oil.
sesto elemento
sesto elemento SuperDork
6/8/17 9:08 p.m.
Winzer poly lube.
fasted58
fasted58 MegaDork
6/8/17 9:13 p.m.
Synthetic gun oil
jere
jere HalfDork
6/9/17 6:02 a.m.
Tri flow or 3in1 work great and can be used in old singer sewing machines with brass bearings too.
kazoospec
kazoospec SuperDork
6/9/17 6:12 a.m.
Out of both curiosity and necessity, do these recommendations change for the ignition cylinder?
Daeldalus
6/9/17 7:55 a.m.
Also I thought I should mention that I live in a really dusty area. It's bad enough that I have to clean dust out of the screw holes in my door pull.
I found out that my work sells the ac Delco stuff and cheaper than amazon.
KyAllroad
KyAllroad PowerDork
6/9/17 9:23 a.m.
https://www.amazon.com/HOUD1-Houdini-Lock-Lube/dp/B00C5JFKKE/ref=sr_1_1?ie=UTF8&qid=1497018135&sr=8-1&keywords=houdini+lock+lube
I use this. It's citrus based so it smells nice and it doesn't gum up like WD-40.
And I didn't stay at a Holiday Inn Express last night but I am a professional locksmith.
JHaNU3QY5ytCF3zEvfnTnTlKNZOPIzt2FOK3LZLJkht4LrpyvGGJ44vZvRKzMNXd
