wvumtnbkr
wvumtnbkr Dork
11/17/14 7:32 a.m.
Yep, rear. It really helped the car carve corners much better. Stock, these things push like crazy and don't rotate that well. IMHO.
gearheadE30
gearheadE30 New Reader
11/17/14 8:40 a.m.
I would wait on the big rear bar until you get a posi in there. Big rear bar plus open diff makes for a lot of one wheel wonder moments.
ProDarwin
ProDarwin UltraDork
11/17/14 9:50 a.m.
wvumtnbkr wrote: Yep, rear. It really helped the car carve corners much better. Stock, these things push like crazy and don't rotate that well. IMHO.
Huh. I would think big front would be the answer here. Its extremely rare to see a competitive RWD car with a huge rear bar and stock front bar. Or a huge rear bar at all.
G_Body_Man
G_Body_Man New Reader
11/17/14 11:14 a.m.
Thanks for all the suggestions, guys! Is there an LSD I can get for the 7.5?
Wally
Wally MegaDork
11/17/14 3:17 p.m.
Some Monte Carlos had posis, as did some of the Grand Prixs.
G_Body_Man
11/17/14 3:24 p.m.
In reply to Wally:
Thanks for the tip!
Kenny_McCormic
Kenny_McCormic PowerDork
11/17/14 6:42 p.m.
I wouldn't bother putting a lsd in a 7.5, especially in car that big.
Wally
Wally MegaDork
11/17/14 8:19 p.m.
My Monte has a 7 5/8" with 3.73s and a posi and it's still good with about 175000 miles on it.
Kenny_McCormic
11/17/14 8:34 p.m.
In reply to Wally:
How much power do you feed it?
wvumtnbkr
wvumtnbkr Dork
11/18/14 9:55 a.m.
we road raced on a 3.73 7.5" posi for a number of years with zero issues. This was living behind a decent 350 sbc with some minor mods (headers, tuned, cam).
Never once had any rearend issues.
as far as the swaybar is concerned, these cars aren't exactly sportscars. The front end geometry needs fixed before you do anything to the rear.
On these cars, rear swaybar diameter doesn't have as large an impact on the balance of the car. The rear swaybars on these do not attach to the chassis at any point. They go from one lower arm to the other. For this reason, you WILL see a large to huge swaybar on the back of these cars for road racing / autocross. That is, unless the rearend is changed to a different setup (get rid of the 4 arm setup).
Hope this helps clarify the situation.
P.S. large front swaybars will negatively impact front end grip with a well designed suspension setup.
81cpcamaro
81cpcamaro HalfDork
11/18/14 10:11 a.m.
I would recommend a rear bar like this one: http://scandc.com/new/node/684 if you are changing/adding one. It does attach to the chassis, is adjustable and works better than the stock design.
As for posi diffs, you can also get them from 3rd and 4th gen camaro/firebirds, just watch for the axle spline count. Early ones are 26, later are 28 spline.
G_Body_Man
G_Body_Man Reader
11/18/14 10:30 a.m.
In reply to 81cpcamaro:
Thanks for the info! I'm going to work on the vehicle this weekend, so I'll keep you guys posted in my Build Thread.
wvumtnbkr
wvumtnbkr Dork
11/18/14 10:41 a.m.
81cpcamaro wrote: I would recommend a rear bar like this one: http://scandc.com/new/node/684 if you are changing/adding one. It does attach to the chassis, is adjustable and works better than the stock design. As for posi diffs, you can also get them from 3rd and 4th gen camaro/firebirds, just watch for the axle spline count. Early ones are 26, later are 28 spline.
Agreed! That is probably the better way to go.
G_Body_Man
G_Body_Man Reader
11/18/14 12:00 p.m.
In reply to wvumtnbkr:
Better save up, then. Or should I work on getting the 0-60 below 10 seconds.
NZPnaw4J4hCCDnNMVydHqqTJdxIx4HBQiK6UJQLFVFrFGNjmYuAhaZQ6sHwLsi4g
