Strike_Zero
Strike_Zero Dork
3/28/12 12:37 p.m.
I stumble across the unloved 4.3 GENII "baby LT-1" when helping a friend move some stuff around his in-laws shed.
Since I probably can get this thing stupid cheap (think c-note + half), should I pass or grab?
4.3 + turbo + T-5 + cheap Volvo wagon would be a riot!!
HiTempguy
HiTempguy SuperDork
3/28/12 1:04 p.m.
Pass. Actually, light it on fire, then don't call the fire department. You'll be doing the world a favour.
Appleseed PowerDork
3/28/12 1:30 p.m.
Bullet prof as the LT1. If you already have it, do it stick it in the Volvo. Junkyard parts are plentiful because no one wants an L99. Dunno what can swap from LT1 to L99 as far as speed parts are concerned.
Conquest351
Conquest351 Dork
3/28/12 1:46 p.m.
Is that the same engine they had in the Syclone/Typhoon? If so, then there's quite a bit of go-fast parts available.
Bobzilla
Bobzilla SuperDork
3/28/12 1:48 p.m.
No, Sy/Ty was the 4.3L V6. L99's were small bore LT1's that were hampered by valve shroud, terrible combustion chambers and Optispark.
Sell it, buy a real SBC and go with that.
curtis73
curtis73 SuperDork
3/28/12 2:19 p.m.
Pass. I was offered one for free and passed it up. Tiny bores, nothing really swaps over to an LT1 except intake and external bolt-ons.
Conquest351
Conquest351 Dork
3/28/12 2:23 p.m.
I saw 4.3 and immediately assumed it was the V6. Didn't even realize they made a 4.3L V8... Yuck...
AutoXR
AutoXR HalfDork
3/28/12 3:47 p.m.
I read an article a while ago about using that motor with an LT1 crank to make a 302 chev... Not sure if it was CC or hotrod.
Appleseed PowerDork
3/28/12 4:39 p.m.
Should have read the OP better. I restate my opinion based on if it was running AND free.
patgizz
patgizz UltraDork
3/28/12 7:06 p.m.
autoxr - they used the 4.3 crank in the lt1 block to make the 302.
if it was free i'd take it otherwise i wouldn't pay more than scrap value for one.
Strike_Zero
Strike_Zero Dork
3/29/12 9:44 a.m.
Well I was going to at least give him scrap value for it . . .but he wanted $400 for it . My friend asked him if he was trying his hardest not to sell it . . .
patgizz
patgizz UltraDork
3/29/12 10:52 a.m.
damn. theres a guy on the impala ss forum with a complete 89k mile LT1 with harness/pcm/accessories for that.
Strike_Zero
Strike_Zero Dork
3/29/12 11:17 a.m.
o rly . . .
Linky?
EDIT: Found it . . . too far away
Knurled
Knurled Dork
3/29/12 11:49 a.m.
From what I've seen, (I researched these engines a little bit) they use the same piston compression height as an LT1, the difference is the L99 has longer rods.
So the L99 has nearly 6" long rods. Should be 5.94" c-c. You could make a long rod 302 with an LT1 engine and L99 rods/crank. Breathe like an LT1 but more RPM and less torque, just what a lightweight traction-limited car needs.
I've heard too much about LT1 bottom end issues to be seriously interested in the idea. (Lightweight wristpins or weak pistons or something leading to oil leaks when a flailing broken rod pokes holes through the pan) Plus, L99s seem to cost more than B-body LT1s.
Steve Chryssos
Steve Chryssos Associate Publisher
3/29/12 2:45 p.m.
Actually they make totally awesome wheel chocks. I tried it once and the car in question did not budge one little inch.
CBBm3vXidf23OVqcEk149M1lT9A2PZ1DF5WHrIc1IPmthaKITyMvWwKFIJX6o99M
