rslifkin said:
As far as comfort goes, as long as the shock valving is well matched to the springs, you have enough travel and the bumpstops are progressive enough when you do hit them, it'll ride at least pretty decently. Running out of travel in a too-soft suspension will often feel worse than having something stiffer.
Being that you're local, I'm happy to take you out for a ride in the Jeep as an example of ride quality on much stiffer than stock suspension (it's +47% spring rate in the front over stock, +118% in the rear at ride height and more as it compresses due to progressive rear springs).
Thanks rslifkin! I don't know what Jeep spec'd originally, but those seem like some pretty healthy increases, and good to hear it's still daily drivable. I think I've actually seen your Jeep in Webster before...you should come out to play next winter in the FLR road rallies, as it looks like you're all set up for it!
adam525i said:
As another data point
2005-2009 Outback - KYB GR2 Struts -
- Front - 20.05" extended, 15.15" compressed, 4.9" of stroke
- Rear - 18.01" extended, 12.75" compressed, 5.26" of stroke
2000-2004 Legacy - KYB GR2 Struts -
- Front - 20.71" extended, 14.09" compressed, 6.62" of stroke
- Rear - 17.75" extended, 12.51" compressed, 5.24" of stroke
If you have a U-pull yard close by they can be a great place to go take measurements and get cheap parts to try out before spending a bunch, for example the Legacy struts give you a lot more travel but you don't know if your tires will clear so this could be a way to confirm that (besides more internet research to see if others have squeezed Outback wheels and tires under their Legacy's).
rslifkin is right though, high spring rates matched to the shocks do ride surprisingly well. I just wouldn't want to give up any travel (droop or bump travel) over stock in this application (or any daily driver with our roads in Ontario).
Adam
Thanks Adam - much appreciated. I did a bit more research and it seems like Legacy struts can cause contact at full lock when installed on an Outback with Outback-sized wheels. It's a little unclear if there was also lowering involved, but for mainly rough road based stuff, I'm expecting standard travel should be okay.
As I'm already way too deep in other projects, I took the simpler (and cheaper) way out. Rock Auto had good prices on KYB struts (including a half-price "wholesaler closeout" on the front right), so I picked up 00-04 Outback KYB GR2 front struts, 05-09 Outback KYB GR2 rear struts, and a set of Rallitek springs (0" lift front, 0.4" lift rear) for the 05-09 Outback. Also threw new strut mounts, boots, and bump stops in so that I can just assemble off the car, remove the old, bolt in the new. After the cheaper price on the one strut, GRM discount from RockAuto, $40 rebate from KYB for a set of 4, and a $84 discount on the Rallitek springs, it ended up being a bunch cheaper than the Neomax coilovers, and I can bolt it in and forget about it. I have too many projects going on already...I probably don't need to add my DD into the mix.
Thanks again!
Jason
