shadetree30
shadetree30 Reader
5/31/13 2:20 p.m.
I'm stalking a '02 E-250 with a triton V-8.
What possible concerns could there be with that engine...IIRC spark plugs can be an issue (?)
belteshazzar
belteshazzar UberDork
5/31/13 2:59 p.m.
they could pop out and take the threads with them. not much else for chronic problems by 2002. intake manifold could get leaky. they're cheap to replace.
shadetree30
shadetree30 Reader
5/31/13 3:24 p.m.
I haven't investigated yet; (e.g., haven't accosted the owner and driven it or heard it run, etc.,) but I recall hearing rumblings about the blown-out plugs. One board I looked on had like 50% says "they all do it" and 50% say they're fine. Is there a pre-emptive fix or operation; one wonders if it's still being driven 11-12 years later has it been fixed permanently?
Javelin
Javelin MegaDork
5/31/13 3:42 p.m.
In reply to shadetree30:
It's a manufacturing/design defect (not enough threads in the hole). Some engines spit out all 8 in under 10K miles, others went 300K without an issue. Most are somewhere in-between (mine spit out 2 in succession around 145K and none in the 3 years since). When they do go, they take out the coil ($$$). No per-emptive fix beyond threading the heads...
Tom_Spangler
Tom_Spangler Dork
5/31/13 3:51 p.m.
Javelin wrote: In reply to shadetree30: It's a manufacturing/design defect (not enough threads in the hole). Some engines spit out all 8 in under 10K miles, others went 300K without an issue. Most are somewhere in-between (mine spit out 2 in succession around 145K and none in the 3 years since). When they do go, they take out the coil ($$$). No per-emptive fix beyond threading the heads...
The coil doesn't have to be $$$. Yes, if you buy them individually at a parts store they are ~$50 each, but I got a set of 8 Accels from Summit for $200 for my old 2000 F-150.
belteshazzar
5/31/13 4:16 p.m.
i've got a pile of those coils laying around. they're cheap.
chandlerGTi
chandlerGTi Dork
5/31/13 7:15 p.m.
Sludge issues also; doesn't seem to be in all engines but quite a few develop a nasty knock that signals the end.
shadetree30
shadetree30 Reader
6/1/13 6:19 a.m.
I suppose then that once the plug hole is fixed CORRECTLY it's no longer a problem...Then I guess my strategery would be to ASK if it's been done then if I get the deer-in-the-headlights look to then walk away.
Also listen for knocking...
Thanks, all...
Q7yaBiwfwuXJVjzSoX4pK8UJZvu9B0InYUcBL7zjLBT4FftD17GA0PusRV4a7KsQ
