The OEs are required to use a certain measurement standard, just like they are for fuel economy. It's the aftermarket that's dodgy. Interestingly, GM quotes SAE numbers for their crate engines that are found in production cars (such as the LS3 crate) but something more optimistic for the crate engines that are not (such as the LS3 crate engine with the Hot Cam).
KyAllroad wrote:
I don't understand why it should be a percentage of power lost to driveline gremlins. If I bolt a 200 hp motor to the same transmission as I pair with a 1,000 hp mill, how does it use up 5X on the big motor?
I'm not even sure I'm asking this right..... it just feels like a weak motor would suffer a greater percentage of loss to driveline friction than the more powerful engine.
There are two aspects to driveline loss: frictional and inertial. Frictional losses are pretty easy to understand and are fairly consistent. Figure the driveline (and rollers, etc) will suck up a fixed amount of power. So a 100 hp and a 200 hp version of the same car will have similar frictional losses.
Inertial are more interesting. They're based on the rate of acceleration. A dyno that measures power (torque, actually) at set rpm points with the engine at a constant speed will have zero inertial losses. One that runs through a sweep quickly will show much higher inertial losses than one that runs through the sweep slowly. On a sweep, the inertial losses are closer to a percentage - that 100 hp car will have half the inertial losses of a 200 hp car.
Fun dyno chart. This is the same car on the same dyno, but we took 15 seconds for the full (red) vs 25 seconds (blue). The difference is inertial losses.
https://www.flyinmiata.com/tech/dyno_runs/NC_sweep_times.pdf
If you're a tuner trying to exaggerate the gains on your dyno, you'll always use a percentage. On a 1.6 Miata, you see about 25 hp between the published flywheel specs and the measurement at the wheels on something that reads like a single-roller Dynojet. That's about 25%. So when you ram that engine full of boost and pull 300 hp at the wheels, you'll add 25% to claim 375.
If you're looking for a pessimistic number ("we know it makes at LEAST this much"), you assume those are frictional losses so you add 25 hp to claim 325. This is what we tend to do if someone really really really wants a flywheel number. We prefer to quote wheel hp.
I believe the Brits do a coast-down test to basically measure the inertial and frictional losses, then add them back in to come up with a flywheel number. Of course, if the time of the coast-down is different than the pull, you'll get incorrect inertial numbers.
In reality, it's a mix of both.
Note that drivetrains are getting more efficient in an attempt to improve fuel economy figures. Either Mazda is totally sandbagging on the ND Miata engine or that's one really efficient trans, as they're pulling numbers at the wheels that are higher than expected. I'm voting for the latter.
Also, every aftermarket dyno reads lower than every other dyno.
