WonkoTheSane
WonkoTheSane Dork
3/9/18 11:17 a.m.
Devilsolsi said:
ncjay said:
I had a similar instance a while back. The alignment got knocked off just enough and it needed a tie rod. Rare instances a toe in/toe out problem gets the tire humming. Always a good idea to check ALL your steering and suspension pivot points and do an alignment.
Hmm that is an interesting thought. At the very least I will drive it and see if pulls at all to either side. An alignment probably isn't a terrible idea at this point anyway. Last year she hit a pot hole hard enough to flat spot a wheel on the other side.
You'd have thought it would just naturally balance itself out, then..
vt75eNK4oReaBAP7uyy1wR4TfOiB75o1YMz5eQ58fI1fMqJlgYPd6fhkfEhQ0I4k
