bravenrace
bravenrace SuperDork
12/6/11 11:31 a.m.
Okay, I need to get some for the Koni's on our autocross CRX. The natural choice is Ground Control, but are there any other options I should consider, especially cheaper options? Or is GC the way to go? If so, why?
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
12/6/11 11:34 a.m.
Ebay sleeves and dirt track springs?
That said, i don't really know of any BETTER options than the Ground Controls. Just cheaper and/or equal performance.
e_pie
e_pie Reader
12/6/11 11:41 a.m.
For the price you won't really get much better than Ground Controls.
Raze
Raze SuperDork
12/6/11 11:42 a.m.
92CelicaHalfTrac wrote: Ebay sleeves and dirt track springs? That said, i don't really know of any BETTER options than the Ground Controls. Just cheaper and/or equal performance.
Used Ground Controls?
Used ebay sleeves and used dirt track springs?
Matt B
Matt B Dork
12/6/11 12:18 p.m.
My understanding is that the ebay stuff generally degrades much faster than the GC stuff (i.e. adonizing falling off, seizing, etc.) That said, I don't have any personal experience with the cheap stuff and plenty of people seem to get away with it. If the car only sees fair weather and/or is an autocross only car you could probably get away with the cheapies for a while. Then again, I like to know my suspension items won't catastrophically fail on the way to autocross from hitting a nasty pothole. I'm probably just making that up in my head though.
92CelicaHalfTrac
12/6/11 12:25 p.m.
If i were in this same situation, i'd just look for used GC sleeves only, then fill them with springs of my choice. Eibachs are not the cheapest thing out there.
bravenrace
12/6/11 12:26 p.m.
I guess the question lingering in my head (until it finds it's way to a hole...) is if there is a kit that is just as good but cheaper. Are all the kits on Ebay the same? I haven't looked yet. If not, what should I be looking for? The car is driven a lot, but hopefully won't be driven in the winter. If it is, it's likely that I'll swap stock stuff back onto it until spring.
I do live in northeast Ohio, pothole capital of Ohio, so I don't want to run junk. I also need to figure out a spring rate that will work decently on the course and not break my back on the road. I think in ST the hot setup is way stiffer than I could deal with on the street. Anyone have any experience with this and have a suggested f-r spring rate?
bravenrace
12/6/11 12:31 p.m.
92CelicaHalfTrac wrote: If i were in this same situation, i'd just look for used GC sleeves only, then fill them with springs of my choice. Eibachs are not the cheapest thing out there.
I've been looking for a long time and have never found even one set for sale. Where might I find these elusive sleeves?
92CelicaHalfTrac
12/6/11 12:39 p.m.
I've seen 'em a couple times on Miata forums in particular.
I bet you could also order just the sleeves from Ground Control if you called them.
I got mine used from STS_ZX2 on these forums, but they did come with springs. One pair of Eibachs, and one pair of QA1s.
bravenrace
12/7/11 8:35 a.m.
Anybody else have any ideas on brands or sources?
doc_speeder
doc_speeder Reader
12/7/11 9:22 a.m.
The collar on the GC's really is the cats meow IMO, provided you don't go all gorilla on the locking screw. I had mine on through several salty winters and never had a hint of seizing/sticking/galling etc. Really good design.
Curmudgeon
Curmudgeon SuperDork
12/7/11 9:35 a.m.
GC's design is very good. Had them on Stinky, my '79 RX7. Good quality stuff.
The flEbay sleeves will work but the spring quality is reportedly very bad. The sleeves themselves are sloppier than the GC's and use the double nut lock system, not my favorite. But they are a lot cheaper. You get what you pay for.
car39
car39 HalfDork
12/7/11 10:07 a.m.
$600 Autox special: flea bay coil overs and springs for $200
Track Miata: GC coilovers and eibachs from Flyin' Miata with a set of their bump stops.
Different missions; different prices
klipless
klipless Reader
12/7/11 10:22 a.m.
The MotoIQ guys seemed to like the Skunk2 stuff, although I doubt it's cheap. Linky
Of course these guys also make exhausts out of Al-you-min-eum, so use at your own risk.
Karl La Follette
Karl La Follette Dork
12/7/11 10:52 a.m.
Just picked up 4 new wrx s from birthday boy
Hasbro
Hasbro Dork
12/7/11 3:14 p.m.
^ I bought a used set and bought Swift springs.
nLU9g4hMl3A1NnRqXfGC0H3XfXFU1vofOIV79eFUxVltCgZXI2ICiEXOlsDTf6vS
