Yeah, it is a textbook example of a linear power curve. On the street, below 3500rpm it feels like an NB with maybe a little more kick. Then it takes off like a rocket ship and just keeps pouring on the coals. I broke the tires loose in the rain from a roll at the top of 2nd gear, which completely caught me off guard. And when you are cruising, it is completely unobtrusive.
I originally looked heavy into Eaton blowers because I wanted some low-end punch, but I saw a few issues there. A) There aren't many new kits except for the Fast Forward kits (the pricey ones with the goofy fifth injector) so you are getting into used secondhand stuff that is often in need of overhaul or missing parts. B) The numbers for a lot of them just weren't that great. C) Heat-soak. Talked to the owner of a Jackson-blown Miata and he said on a dyno, the first pull was stout, second pull was down from the first, third pull was stock N/A power levels. I was still considering them, due to the fact that they are typically cheaper and I could use the money saved to vent the hood and run a meth/water injection system, but the mutt nature of my engine swap caused some confusion on what I exactly needed, and there doesn't seem to be much knowledge.
I also considered a turbocharger kit. Problem was, at the time, it seemed like some of FM's components were constantly backordered and I didn't want a CXRacing (or similar) chinacharger kit.. I also didn't like how a turbo adds extra coolant and oil lines that are potential sources of failure (as the magazine's turbo Miata has demonstrated) and I also don't like that it shares oil supply with the engine. In the event of a turbo failure it contaminates your engine oil, and vice versa. Not a fan. Turbochargers also seem kind of fiddly in general.
I settled on the TDR Rotrex kit after a suggestion from Jaynen and doing some reading, and remembering an article where Hot Rod delved into the Rotrex. I liked that it was a fully comprehensive kit that addressed everything (like ducting for the traction fluid cooler) and that they had spent 2+ years developing the kit before releasing it on the public. Also, you can't just go on their website and order a kit, you call them and they ask you questions and take your info and configure the kit to your car. For example, I told them I had a Koyo radiator and they gave me the heads-up that it doesn't work with their charge piping due to Koyo's extra-tall top tank. And when I informed them that I was running Megasquirt, they swapped up to 700cc injectors and sent me a charge pipe with an IAT bung and a MAF delete. The customer service was just absolutely phenomenal.
Also, swaying my choice a little: the kit looks super bitchin' when installed, with the laid-back radiator and charge piping over the radiator and new close-out panels. And I have seen numerous turbo kits, Jackson blowers and every engine swap under the sun in person, but I have never seen a TDR Rotrex Miata in person ever.
The only downsides are A) price. Not a cheap kit. B) Rotrex superchargers don't sound particularly cool. At idle they sound like a broken A/C compressor and under power they don't have the cool whine of an Eaton. But that's a really minor complaint
