YamahaV2_0
YamahaV2_0 New Reader
8/3/22 5:46 p.m.
It's been a good little bit since I've been on here, so long in fact my old account(wowreallypaul) seems to have vanished.
Anyways, I ran into a fun problem while replacing the turbo on the bike.  The a270 marked stainless bolts actually bent slightly and where colored like the rainbow from the heat. I know Inconel is the next best thing for this, but cannot find m8x1.25 cap screws(18, 25, & 35mm) or m10x1.50 45mm long bolts for sale anywhere. And when I do find a source, it's distributor level quantities.
My manifold is not set up to run studs, so this is making it even more fun. I'm guessing the old bolts bent due to both heat and pressure, but am not entirely sure.
So, as the thread title states, I'm after basically a turbo kit worth of inconel hardware and am having a heck of a time finding  it. Thanks, and hopefully I'll be checking back in with everyone soon. Paul
wearymicrobe
wearymicrobe PowerDork
8/3/22 5:50 p.m.
The one and only time I have used these where we could not find something of the shelf the machine shop made inserts for the holes so we could use off the shelf bolts. I cannot even begin to help you find a supplier but looking at some of our books we used someone called. "vision alloy" at one point.
WonkoTheSane
WonkoTheSane UltraDork
8/3/22 5:56 p.m.
If you can use studs, Flyin Miata had the best price on a package of studs with the locking hardware in m8x1.25 back when we were trying to upgrade our SR20 stuff...
Slippery
Slippery PowerDork
8/3/22 6:01 p.m.
Manifold to downpipe bolts on e36 M3 are inconel.
BMW PN 11621427586
Size M10x40mm. Not sure on the pitch.
Otherwise maybe get in touch with these guys:
KD Fasteners
kb58
kb58 SuperDork
8/3/22 6:27 p.m.
Recommend exercising your Google-foo to see what hits you get. Price wise, probably the the cheapest way is finding an aftermarket performance auto parts supplier that carries what you need, typically studs. I found some to mount a turbocharger.
YamahaV2_0
8/3/22 7:06 p.m.
In reply to Slippery :
KD were the first I contacted, didn't sell small quantities.
I might have to look into the bmw bolts though. It might make bolting it up a PITA being 5mm shorter, but they might work in a pinch. The biggest thing for me on Inconel would be the M10's, as that's my manifold to turbine housing. The m8's are just for the 5 bolt outlet and external wastegate to the manifold and exhaust.
YamahaV2_0
8/3/22 7:08 p.m.
I give up about 10 pages worth of unproductiveness in......only thing that uses studs on the exhaust of this bike is the  manifold to head, and that's already Inconel with copper nuts.
triumph7
triumph7 HalfDork
8/3/22 10:47 p.m.
Check Aircraft Spruce, lots of airplanes use inconel hardware.
jfryjfry
jfryjfry SuperDork
8/3/22 10:49 p.m.
Aren't the Nissan sr20det turbo studs and nuts inconel??
Brett_Murphy (Agent of Chaos)
8/4/22 2:38 a.m.
The turbo RX-7s used Iconel nuts on the manifolds. I'm not sure of the size anymore, but your local dealer may be able to get them.
MadScientistMatt
MadScientistMatt UltimaDork
8/4/22 12:56 p.m.
Some sources may list them under "nickel" instead of Inconel.
8/4/22 1:12 p.m.
Purple Frog (Forum Supporter)
Purple Frog (Forum Supporter) HalfDork
8/4/22 1:20 p.m.
We get a lot of race car hardware from these folks...
https://monroeaerospace.com/
8/4/22 4:14 p.m.
Dunno about the inconel but it seems like your old account still exists, try signing in with username yamaha:
https://grassrootsmotorsports.com/community/yamaha/
YamahaV2_0
8/5/22 6:27 p.m.
Good call, I'll have to check on it. I'm just hoping it's email isn't tired to the work email from back then.
YamahaV2_0
8/5/22 6:28 p.m.
In reply to Purple Frog (Forum Supporter) :
That's a different one, will have to check it out.
WOW Really Paul?
WOW Really Paul? MegaDork
8/5/22 6:32 p.m.
In reply to GameboyRMH :
Many thanks, last I knew this was set to WowReallyPaul and couldn't find it.
Edit: and amusingly, it still is.
5uM5LnaTk3ahekmm0GPBw9C24LtKD2wxB37OkwEgWpL3vjUSJC7eN3gtvPPCVYNE
