In reply to Racingsnake :
I wanted a 4 on 4.5" bolt pattern to match my FC RX-7 front suspension, so I had axles made by Dutchman to my specs. I also wanted to widen the track by an inch because I was getting tire rub on the inner fenders with the RX-7 axle, and move the pinion over a little to the left because the RX-7 pinion flange hits the right side of the tunnel. Basically it is an axle for a 58" rear on the left and a 60" rear on the right, for a 59" flange to flange width.
The main reason I used the 9" over anything else, besides very cheap gears and diffs, is the pinion flange to axle distance is almost the same as the short nose Mazda 7". I acquired a Thunderbird pinion flange and had it machined to take the Mazda driveshaft.
Rotors are from the rear of a NEDCAR Volvo S40 (2004-earlier), like $10 each. Dutchman doesn't do stepped wheel/rotor registers, so I had the axles made with the Mazda register and had some centering rings made locally that were the same thickness as the rotor hats. (Being a Mitsubishi design, the rotors have ridiculously large pilot)
Calipers are from a VW, not Audi - first generation New Beetle and other A4 chassis cars. (Contemporary Audi A4s were built on the B5 chassis - VWAG started their chassis naming convention before they started calling Audis A(x) ) Front drive Audis appeared to use the same beams, or at least the same at the business ends. The Volvo and the VW both used Lucas rear calipers so the pads are even the same, but the VW calipers are aluminum and the hand brake cable setup was much more adaptable to the Mazda - just trim a notch in the housing bracket, and widen the cable mount slightly. And clock the calipers roughly 45-60 degrees down so the cables could reach. Axle housing brackets for some flavor of Wilwood caliper had the same center-center distance so those were cut down to suit the small diameter rotors.
If I were to do it again, I'd have used FC RX-7 four lug rotors so that I could move the calipers more inboard so I could use 14" wheels. ACTUALLY if I were to do it again, I would ring up Speedway (the shop in California, not Iowa) and have them build me a floater rear end. It would probably have been about the same expense, and I found that even with the Torino "big bearing" housing ends I was only getting three or four rallycrosses before the axle bearings were hosed.
Hosing axle bearings is a major reason why I stepped away from the RX-7 rears - axle bearings were a constant issue.
As was, towards the end, just plain breaking axles. As Opti pointed out, a little bracing goes a long way, the final event where I ran the 7" was the event that I broke an axle brace when the jack slipped while I changed a tire. Immediately broke the axle on that side in competition.
No hard numbers on the 7.5, that was a project that never panned out.
