shelbyz
shelbyz New Reader
8/6/14 4:27 p.m.
I've got an opportunity to potentially acquire a 1985 Shelby Charger that a friend will be getting in a trade for another vehicle.
The car would potentially be a project that has been sitting for a VERY long time. While I'm somewhat familiar with turbo Mopars (hence the user name). My experience is just about 100% with the larger K based cars (mostly G and P bodies). Never really dabbled much into L bodies, although I once had the opportunity to get a very clean low mileage Santa Fe Blue GLH-T for a very good price. However, I couldn't come up with the funding, missed out and still hang my head in shame.
I'm fine with the mechanical bits that the car needs, but my concern lies with the L-bodies common downfall - rust. The car is apparently from the South, but has now sat for an extended period in the North. The owner has acknowledged that it has some body rust, and a floor that is "a little rough".
My question is, what would I have to find or not find to decide if the car is worth saving or if the rust is terminal?
moparman76_69
moparman76_69 SuperDork
8/6/14 4:50 p.m.
A little rough = flintstone floorboards
The determining factor is if the frame rail segments under the front floors are intact. Also check the front frame horns around the core support and bumper attachments and the strut tower to unibody weld area and the rear quarters.
SilverFleet
SilverFleet SuperDork
8/6/14 7:17 p.m.
RUST SUCKS.
A car that looks like this on the surface:
May look like this underneath that carpet:
L-Body cars tend to rust more than the rest. A friend's "rust free" GLH-T needed floors all the way up under the dash.
If you do plan on tackling rust repair, let me warn you first by telling you that they pretty much make ZERO rust repair panels for the Turbo Mopar cars of yore. Since you are on GRM already, you probably aren't scared of a little fabrication.
My "new" floors are made out of old scrap from my friend's Omni's own floor repairs, some random scraps intended for a '53 Ford rust repair project, and a 1999ish Subaru Impreza hood. As far as other areas go, you may get lucky like I did with some replacement outer rockers on eBay and NOS fenders from a local source.
My floors look like this now:
ddavidv
ddavidv PowerDork
8/7/14 4:27 a.m.
If it's floors, remember...nobody will see them, so they can be ugly but strong. Provided there's material to weld to around the perimeter, floorpans from darn near anything can be cut to fit. I dislike seeing plain flat steel without some kind of strengthening ribs in them as they can 'oil can'.
SilverFleet
8/7/14 8:05 a.m.
In reply to ddavidv:
When I did mine, I traced crease lines based on the remnants of the floor that was left with magic marker and used a hammer and an old socket on top of my bench vise to bash some ribbed channels in the panel. Crude, but it worked great! There's no "oil can" issue at all.
Dusterbd13
Dusterbd13 Dork
8/7/14 8:15 a.m.
The only two people that will know what your floor looks like are you and the guy you ran over. One definitely ain't gonna care.
SilverFleet
8/7/14 8:30 a.m.
Dusterbd13 wrote: The only two people that will know what your floor looks like are you and the guy you ran over. One definitely ain't gonna care.
And this is why we didn't waste any MIG gas while welding my floors in. It's all gonna get covered with paint, seam sealer, padding, and carpet anyway.
turboswede
turboswede UltimaDork
8/7/14 9:45 a.m.
I loved my L-bodies. Such a light and nimble feeling car compared to the larger Daytona's and Shadows, etc. The SC isn't as fun to autocross due to the longer nose, but it works just as well as any other FWD car and suspension setup, etc. are all well documented around the web.
Biggest issue with leaks and rust, is the cowl seams leak due to the sealer drying up and failing in combination with chassis flex. Check along the base of the windshield under the hood where the wiper motor goes for cracked sealer, if its cracked and hasn't been patched expect to repair that and any rust that might have occured. the floors themselves have seam sealer just behind the pedals where the two panels join together and is another place for leaks and rust to form. Of course any sort of salt in the air or on the ground will just aggravate the issues.
Inner fender wells/strut towers liked to pull away from the frame rails on early cars due to poor spot welding. Later cars that have been driven hard can have the same issue. K-frame's are notoriously flexible due to being made up of a bunch of poorly welded steel. Control arm pivots are poorly designed and contribute to suspension binding and generating random spring rates in the front end.
Front swaybars are more like torsion bars as they bind so badly that they cause all sorts of bad handling (and flexes the crap out of the K-frame and chassis in the process).
Both K-frame and sway bar issues can be fixed with some effort cutting and welding a later K-car frame with the dual pivot style arms and replacing the sway bar with a custom solution that moves the bar away from the K-frame and arms. Look around the local salvage yards for 924/944 front bars as they can be easily adapted to mount to the frame rails and with longer sway bar links won't bind up and you can get them in different diameters to tailor the rate to your liking. Or look at circle track universal bars, they can be found for reasonable money at swap meets and the like.
Decent shocks are hard to come by, Rabbit/Golf struts can be adapted with some work, unless you have some K-car struts then those are a little easier to adapt with the matching uprights and proper axle lengths.
Front core support has failed on some due to bad motor mounts and hard launches. While you're checking/welding the inner fenderwells, throw some welds at the front corners where the core support joins the frame spars and use polyurethane motor mounts to reduce the back/forth motion that causes stress failures.
A525 transaxle is seriously weak and will fail eventually with hard driving. I prefer the shifter linkage setup to the later transaxle's cable solution (once the plastic joints are replaced with proper heim joints that is.) but thats a personal preference thing. Either way, plan on putting a stronger transaxle in, lots of info online on how to do that. On my GLH-T, we swapped it over to an A-520 and I built our own mounts to use the stock rear transaxle mount and run slightly modified stock linkage, there's a kit available online now to do just that which is handy.
Electrical problems abound on L-bodies, gauges like to fail due to bad soldering on the boards, wiring under the hood fails due to the extra heat from the turbo motors in smaller engine bays, they were cheap cars to begin with, etc. Not insurmountable, but certainly something to be aware of.
Due to the tiny nature of the engine bay, I would highly recommend an oil cooler for the cars along with the coolant bypass mod (run a 1/4" line from the top of the water pump to the freeze plug on the end of the head, helps keep number four cooler and you'll pick up some power since the ECU won't have to add more fuel to those cylinders to compensate).
Good luck with it and show us all pictures so we can live vicariously through you!
SRTShitBoxCharger
SRTShitBoxCharger New Reader
7/23/24 1:26 p.m.
In reply to turboswede :
Can you detail how the 944 swaybar works in a charger? I'm seeing two kinds depending on year and one has clamshell style mounts on the ends, and the other has endlinks. Also how is it mounted to the car in the center?
fDi8iNNfXhh5J8ljmiasA6CC85LVX5d083Lpalt9qWkA0T6GtNmvU88KVhkFNj66
