I'm shopping for a rolling tire rack for my home garage, and need to hold at least 6 wheels and tires, each around 11.5" wide (rear wheels/tires from a C5 Z06 with 295/35-18).
From a web search, I found the Tire Rack rolling storage rack that will hold 8 wheels, but it's a little bit long for where I want to store it. Its also a little bit spendy
On Amazon, I found a Sunix rack for 6 wheels (
Amazon ) that would fit my wheels, but I'm not sure how sturdy it is. I need to move wheels from my garage to the house, and don't want to have an unstable stack that's top heavy
Does anyone have any good solutions for a rack that holds 6 wheels? Unfortunately, I don't own a welder and/or pipe bender (yet......)
Could you repurpose a firewood rack?
Know any endurance race teams either upgrading or closing up shop?
I'm partial to pre-loved steel bed frames and 4" caster wheels.
I don't have anything useful to add, but I have to ask...
Why SIX wheels? Are you racing a dually? Or a pair of Morgan three-wheelers? :)
I don't know if this is stable enough for you, but what I've done in the past is stack them flat on a furniture dolly then secure them with a ratchet strap. $15 total at Harbor Freight or the like, and as compact as it gets. Sure if you're careless it can tip over, but put it in a corner and it's not falling over no how.
Look on Craigslist for free or cheap pallet racks , the uprights will need to be narrowed,
but the crossbeans come in all sizes , 4ft and up
Tom1200
UltraDork
4/26/22 4:04 p.m.
I stack mine on furniture dollies.
For any tires that don't fit on my wall mounted rack, I do this.
Except minus the ratchet strap.
I was using the HF furniture dollies quite happily, until I ran over a stone on my garage floor and the stack of 4 toppled towards my 911. Fortunately, they bounced away from the car. This is the event that made me look for a better solution.
In reply to codrus (Forum Supporter) :
I have 6 track wheels and tires. I guess running dual rear wheels would help solve any oversteer issues, though!
Would switching to larger diameter caster wheels on the furniture dollies help? Probably the cheapest solution.
Tom1200
UltraDork
4/28/22 11:40 a.m.
This is exactly what I did. I went to larger diameter wheels so I can push them over the gap/grooves in the floor (post tension slap). You can also make a handle that pushes the dolly from the bottom rather than pushing on the tire.
SV reX
MegaDork
4/28/22 11:49 a.m.
Hand truck with fold down extension.
We move 4 tires at a time routinely with these. Uneven surfaces are no problem.
6 tires would stack on them easily, but you'd have to work a little to move 6.
About 20 yrs. ago I bought a 3 shelf metal industrial rack (5 ft. wide x 2 ft. deep v 5 ft. high) that you normally put plywood on for the shelves. I put 2x4's the length of the bottom rack (no plywood on that section) . I also bought four 4 inch castors, 2 swivel and 2 fixed and bolted them to the bottom of the frame. Installed plywood for the 2 upper shelves that I use for tools and parts.
I would pay good money to see a Morgan 3 wheeler sitting on 11.5" wide wheels all around
