Grtechguy
Grtechguy SuperDork
11/8/08 1:31 p.m.
Just put a new LED taillight on my bike. only thing is that it is no where near the style of the old.
I also want to replace the turn signals with LED units next the new brake light
so, looking to make a new tail section around the light. any recommendations?
clownkiller
clownkiller New Reader
11/8/08 2:01 p.m.
Take a look on youtube on how to make custom speaker boxes. The technique should be simular for your round tail light.
http://www.youtube.com/watch?v=DzZO3M1oymQ&feature=related
SVreX
SVreX SuperDork
11/8/08 3:30 p.m.
Great Stuff. You know, that foam-in-a-can. Use it to make the form.
Spray a glob of it on, let it dry. Use a rasp, cheese grader, or heavy sand paper to shape it as needed.
If there are low spots, repeat.
Once you've shaped the foam into the shape you want, glass over it with a fiberglass patch kit- available at any auto parts store.
Then sand, Bondo the imperfections, finish sand, and paint.
Grtechguy
Grtechguy SuperDork
11/8/08 3:47 p.m.
use something like this?
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=BND&MfrPartNumber=762&CategoryCode=3269
SVreX
SVreX SuperDork
11/11/08 11:08 a.m.
That link doesn't go anywhere meaningful.
gamby
gamby SuperDork
11/11/08 11:32 a.m.
SVreX wrote: Great Stuff. You know, that foam-in-a-can. Use it to make the form. Spray a glob of it on, let it dry. Use a rasp, cheese grader, or heavy sand paper to shape it as needed. If there are low spots, repeat. Once you've shaped the foam into the shape you want, glass over it with a fiberglass patch kit- available at any auto parts store. Then sand, Bondo the imperfections, finish sand, and paint.
Makes me want to fab something up for the sheer helluvit.
The former model car builder in me already has the skillset for the finish work. (I think)
mistanfo
mistanfo Dork
11/11/08 12:05 p.m.
Chicken wire and remnant fleece from your local fabric store does well for speaker boxes, not so well for smaller projects.
Hocrest
Hocrest New Reader
11/11/08 12:32 p.m.
I've used the green foam that is made for flower decorations. The dry gritty stuff. It's super easy to cut and shape for the mold and it doesn't dissolve when the resin hits it.
If you want to use it as a mold more than once, coat it with car wax. Otherwise just put the FG/resin right on it and it will break away.
nicksta43
nicksta43 New Reader
11/11/08 2:37 p.m.
Hocrest wrote: I've used the green foam that is made for flower decorations. The dry gritty stuff. It's super easy to cut and shape for the mold and it doesn't dissolve when the resin hits it. If you want to use it as a mold more than once, coat it with car wax. Otherwise just put the FG/resin right on it and it will break away.
I've had luck with this method. I glued aluminum foil to the mold and was able to use it several times.
Grtechguy
Grtechguy SuperDork
11/12/08 7:07 p.m.
SVreX wrote: That link doesn't go anywhere meaningful.
sorry...it asks for zip code? enter 49428
SVreX
SVreX SuperDork
11/13/08 12:31 p.m.
Ok- that stuff will work fine over a form.
The Great Stuff foam I am suggesting will be the form. That flower styrofoam others have suggested will work fine as a form, but it will be harder to shape in your situation. You can leave it in when you are finished, or gouge it out if you prefer..
The Great Stuff can be sprayed directly on what you've got.
Then, use the stuff you linked to (what I called a patch kit in my earlier instructions). Or, you can buy the other kind (resin and hardener in one can, plus small fiberglass mat). Both will work for something that small.
walterj
walterj HalfDork
11/13/08 12:47 p.m.
For something larger... say a bumper for a E30 to clean up the aero and mount a splitter to... would you use multiple applications of cloth+resin? Will I need to move out of my house for 3 days while it cures? How would you make stronger bosses for bolts to go thru?... can you embed aluminum tabs and have it adhere or would the stuff not stick to it?
IW43ReQpCWqRfRK6QhqbTRwwdpP2JgQPuIdPbqZMSLLv60DoeHKAuZxAmKwI1AQc
