thatsnowinnebago
thatsnowinnebago SuperDork
4/30/18 4:29 p.m.
In reply to Antihero :
At least it's an easy fix.
Antihero
Antihero HalfDork
4/30/18 4:40 p.m.
True, and i shouldnt have overthought it and just taken a look at it
Vigo UltimaDork
4/30/18 7:57 p.m.
A berkeleying spark plug is loose on one side, apparently instead of over thinking it i should have just looked at it. Since both banks are lean im betting theres one on the otherside thats a little loose. Hows that for a stupid problem ?
Ehh, maybe not. With a wasted spark ignition system each coil is hooked to two spark plugs, and if one of them goes open-circuit for whatever reason the other one will fail to fire as well. And since cars use oxygen sensors and not Air/Fuel Ratio sensors, the o2 just sees all the oxygen coming out of the non-firing cylinders (that didn't get combined with nitrogen or carbon because no combustion happened) and thinks the engine is running lean, thus driving the fuel trims rich and exacerbating the problem.
Let us know if it actually fixes it..
Antihero
Antihero HalfDork
4/30/18 8:09 p.m.
You were right, only one plug was loose and after tightening it up...no check engine light, no codes and fuel trim is way lower than before.
Im happy it was such an easy and low cost fix, sort of pissed at myself for not just looking right away even though busy life etc
Recon1342
Recon1342 Reader
5/1/18 10:27 p.m.
Meh, no biggie. That’s how you become a better mechanic!
gearheadmb
gearheadmb SuperDork
5/2/18 7:12 a.m.
Don't be mad that you missed it, be happy that it didn't spit the plug out along with the aluminum cyl head threads.
Antihero
Antihero HalfDork
5/2/18 8:46 p.m.
Very true
Antihero
Antihero HalfDork
5/2/18 8:46 p.m.
You are not wrong there lol
psjymzOqPhi1IR2jHmi488gXeHHOOOI6pQzMHhEyjZy3Gm08kMVNFRZWMYxDGKMh
