Woody
Woody SuperDork
5/15/11 3:59 p.m.
You people had better appreciate this.
Last week, I added a couple of posts to this thread, regarding comfortable race seats in a Miata: http://grassrootsmotorsports.com/forum/grm/daily-drivable-racing-seats/35229/page1/
I had a few photos of various rail options and mentioned that I had heard about people modifying the floors and stock seat rails to sit lower in the car. Since I'm in the middle of installing a Hard Dog cage and race seat in my own car, I happened to have at my disposal:
  • a '96 Miata who's factory rear seat mounting bumps have been removed
  • a bunch of extra stock sliders
  • and a couple of spare '95 M Edition seats (currently for sale)
I decided to see what I could gain by lowering the rails.
As you can see, I drilled out the spot welds on the factory mounts (using an Eastwood Spot Weld Cutter) and removed them. Be careful not to drill straight through the floorpans. These are what I removed (these two photos are of my old car; eventually, I welded these back into that car): Photobucket
Here's what you're left with, after grinding the rest of the welds off and adding a little primer (ignore the extra holes in the floor):
Photobucket
I had a stripped down stock seat rail that I used to mock up the proper angles. It was easier to work with and you can see the angles better. First, I cut off the locating pin, since the new angle of the rail tabs create an alignment problem with the original pin hole. (As an alternative, I could have enlarged the locating pin hole in the floor.) I cut the pin off with a reciprocating saw, leaving about an eighth inch of material on there, as it doubles as a rivet, holding two parts of the rail together.
Photobucket
Then I heated and bent the front mounting tab down a little and the rear tab up a lot. I also used an angle grinder with a flapdisc to smooth out the bottom side of the tabs, removing the lip that's leftover when the original holes were stamped. Here's what it looked like when I was done (the magnet in the middle is just holding it in position to show the new angles):
Photobucket
Here's how my prototype rail sits in the car:
Photobucket
Note that the rear bolts would pass through the two dimples in the floor pan. Those were put there to allow clearance for the ends of the original rail mounting bolts, after they pass through the threaded floor mounting bumps. It would be wise to flatten these with a hammer and dolly before bolting down the modified rails. Later, you'll need to drill a hole through the floor and bolt down the back of the rails. Don't drill until you have the seat mounted to the rails and the front rail bolts in place, so you know exactly where to drill the holes. You would need to add a large (2"x2") steel backing plate or large heavy washer under the floor to prevent the bolt from pulling through under load.
Photobucket
Then, using my prototype rail for reference, I removed the pins and transferred the new angles to a set of complete rails. The prototype is nearest to the camera and the unmodified original is behind it. This should give you a good idea of the new angles.
Photobucket
It is important to note that the new angle of the rear tabs will no longer allow the slider to travel through it's full range of rearward movement, as they now bottom out. You gain a little legroom from the new angle, so this may or may not matter to you.
Photobucket
That same issue creates a little bit of a problem when you go to mount the seat to the rail, as a 12 mm socket is too big to pass through the lower mounting hole. I resolved this by swapping the rear seat-to-rail bolts with a pair of socket head bolts (Home Depot).
Photobucket
Photobucket
Photobucket
This shows that the rear mounting holes fall roughly in the same position as the originals. Note the factory holes in the carpet.
Photobucket
With the seats mounted in the car, you can see that the modification gained about two inches of headroom. The fact that I did this with '95 M seats makes it a little easier to see the difference.
Photobucket
You can just barely see the top of the driver's seat in this photo.
Photobucket
Photobucket
So, after all that, I removed everything and then installed the Cobra race seat that I was working on in the first place.
Photobucket
I hope that someone finds this helpful. It's a reasonable solution that can gain you a couple of inches of headroom. If you combine it with a foamectomy, you can gain even more. (You can see from the photos that I've used two different cars and that there were two different roll bars involved.)
And, on a side note, the '95 M seats are still for sale if you know anyone who's looking for a set.
Joshua
Joshua Reader
5/15/11 4:09 p.m.
Excellent thank you for the write up! I'll have to look at this more closely later.
Woody
Woody SuperDork
5/15/11 4:22 p.m.
Joshua wrote: Excellent thank you for the write up! I'll have to look at this more closely later.
Your thread was the one that got me started on all this!
CarKid1989
CarKid1989 Dork
5/15/11 4:35 p.m.
link/ sticky for FM website? Keith?
Keith
Keith SuperDork
5/15/11 4:47 p.m.
Woody, I'd love to add this to the FM site if you don't mind. I'd prefer to host it on our own server so the link doesn't break sometime in the future - I know there's a rework of the GRM software in the works. I'd give full credit of course.
We just did something similar to a customer car. I think it happened while I was at the Mitty, so I've only sat in the final result. I'll have to see if Tyler has anything to add about what he did differently.
Woody
Woody SuperDork
5/15/11 5:05 p.m.
Keith, sounds good. I'll send you a PM.
Slyp_Dawg
Slyp_Dawg HalfDork
5/15/11 6:57 p.m.
this is definitely going to happen on my Miata, as I am in dire need of at least 2" more headroom due to the rollbar I have ( Hard Dog Hard Core Hardtop M2 bar) and the fact that I am 5'11"-6'0" depending on the doctor you ask, with a 34" inseam, and as the car sits now, my helmeted head is a good 1.5"-2" above the main hoop of the rollbar
Woody
Woody SuperDork
5/17/11 4:31 p.m.
Sale pending on the seats.
Sultan
Sultan HalfDork
5/6/12 8:45 a.m.
Keith wrote: Woody, I'd love to add this to the FM site if you don't mind. I'd prefer to host it on our own server so the link doesn't break sometime in the future - I know there's a rework of the GRM software in the works. I'd give full credit of course. We just did something similar to a customer car. I think it happened while I was at the Mitty, so I've only sat in the final result. I'll have to see if Tyler has anything to add about what he did differently.
Keith, Are you guys still intending to post this? I lost the thread and it took me about an hour to find it across all the Miata websites. Of course GRM is the best of all Miata forums:-)
Keith
Keith MegaDork
5/6/12 12:25 p.m.
I'd forgotten all about it. As much fun as it is building a major free Miata resource, there are sometimes bigger priorities at work
Sultan
Sultan HalfDork
5/6/12 7:06 p.m.
Keith wrote: I'd forgotten all about it. As much fun as it is building a major free Miata resource, there are sometimes bigger priorities at work
Keith = Awesome!
Blackice
Blackice None
4/19/14 12:58 a.m.
Great info, thanks for sharing. I will definitely be making this change to the car....
Thanks Again!
X 2 on getting this on Flyin Miata site. This thread was very hard to find....
cyhMmZG0r1TKA2Rxt6iBzdjBblzyQS7GjxXCMAN36S43sEWFyP726fniwefnaUKk
