taparsons
taparsons New Reader
3/10/15 1:17 p.m.
Im looking to drop an LSx into a solid chassis that either already does or can be made to handle well. Im looking for something that already has the swap kit (mounts) available.
wvumtnbkr
wvumtnbkr Dork
3/10/15 1:30 p.m.
FB RX7
FC rx7
FD RX7
240 SX
Corvette
I think porsche 944 has kits
E36 BMW
etc.....
3/10/15 1:36 p.m.
Buddy of mine has a really nice S14 coupe that's getting the LS2/T56 treatment. Should be fun. I also know where there is a unused Sikky swap kit available for that installation, if you're interested.
bravenrace
bravenrace MegaDork
3/10/15 2:48 p.m.
http://grassrootsmotorsports.com/forum/grm/60-ls-swap-choices/99502/page1/
Kenny_McCormic
Kenny_McCormic PowerDork
3/10/15 3:24 p.m.
How big of a chassis? You can make pretty much any RWD GM product from the mid 60s onward handle well without too much work, and the LSx bolts in with a set of gen 1 V8 mounts and a pair of adapter plates.
NOHOME UltraDork
3/10/15 4:27 p.m.
Miata
taparsons
3/10/15 4:43 p.m.
I know it's a dumb question. I've been trying to mull it over. F bodies are way over priced in my opinion. A decent one is around 8k where I am. I'd rather build something. I was thinking a light chassis 240 miata etc but I also want it cheap. Looks I could care less it will probably end up flat black.
EvanB
EvanB UltimaDork
3/10/15 5:35 p.m.
280zx
kanaric
kanaric Dork
3/10/15 5:51 p.m.
350Z
bluej
bluej SuperDork
3/10/15 6:57 p.m.
How about an e31 BMW? Already have a rear end to handle v8 torque and e36 swap kits are probably pretty close to getting you there.
Plus, so sexy..
icaneat50eggs
icaneat50eggs Dork
3/10/15 6:58 p.m.
z3/4
911
914
Exocet!!!!
Mr_Clutch42
Mr_Clutch42 Dork
3/10/15 7:08 p.m.
You can also do an E34 or a first gen Boxster.
icaneat50eggs
icaneat50eggs Dork
3/10/15 7:20 p.m.
Please do a 911 and show up at all the p club events
Knurled
Knurled UltimaDork
3/10/15 7:29 p.m.
Kenny_McCormic wrote: How big of a chassis? You can make pretty much any RWD GM product from the mid 60s onward handle well without too much work, and the LSx bolts in with a set of gen 1 V8 mounts and a pair of adapter plates.
As long as you don't want A/C...
The two options to make A/C work is to move the passenger motor mount rearward (4"?), which is the best option IMO as long as it clears everything else, or to relocate the A/C compressor elsewhere, which tends to mean that it gets in everything else's way. The water pump design is somewhat limiting as far as accessory mounting is concerned.
Mr_Clutch42
Mr_Clutch42 Dork
3/10/15 8:04 p.m.
icaneat50eggs wrote: z3/4 911 914 Exocet!!!!
The biggest problem with a 911 is that you can't get a cheap one anymore.
patgizz
patgizz PowerDork
3/10/15 8:33 p.m.
lincoln LS.
taparsons
3/11/15 3:01 a.m.
I think everone is missing the cheap part. Lol. Anyone strap one in a old mercedes? They are cheap and plentiful in the sub 1000 range. What about volvo 240s?
oldopelguy
oldopelguy SuperDork
3/11/15 3:13 a.m.
Both of those would be great projects and reasonably easy as swaps go, but I don't think anyone makes kits for either. JTR might have some of the parts for the Volvo, but not everything.
Nathan JansenvanDoorn
Nathan JansenvanDoorn Dork
3/11/15 3:46 a.m.
E28? 944? You reuse the porsche transaxle, which saves you from buying a $$$ T56.
calteg
calteg HalfDork
3/11/15 5:52 a.m.
I've done a LOT of research into this. In order, your cheapest options are:
Swap LS1 back into an F-body
S10
944 turbo (supposedly the non turbo manuals aren't up to the torque)
240sx
turboswede
turboswede MegaDork
3/11/15 8:19 a.m.
calteg wrote: I've done a LOT of research into this. In order, your cheapest options are: Swap LS1 back into an F-body S10 944 turbo (supposedly the non turbo manuals aren't up to the torque) 240sx
Non-turbo transmissions after 87 are just as strong as the Turbo units.
The Turbo gearing is a bit better suited for the V8, but many swap early 5th gears into the turbo transaxle to get a better cruising gear.
bluej
bluej SuperDork
3/11/15 8:34 a.m.
satin black looks pretty good on these..
3/11/15 10:04 a.m.
RX8
3/11/15 10:45 a.m.
F-Body too expensive? Find an equivalent year Nova for far less.
Kenny_McCormic
3/11/15 12:12 p.m.
To expand on that, 68-74 Novas, and their BOP cousins, are pretty much gen 1 F bodies from a mechanical standpoint, the 75-79 is a gen II f body front suspension, and a gen 1 rear suspension.
Birthdays
WPsPJywORR5Ui6nrGbi3yJMHkP45Q1Me2IME51J4ffCTZJ4qDUk9tSsvNZWnLLki
