Mr_Clutch42
Mr_Clutch42 Dork
3/11/15 7:00 p.m.
taparsons wrote: I think everone is missing the cheap part. Lol. Anyone strap one in a old mercedes? They are cheap and plentiful in the sub 1000 range. What about volvo 240s?
Are the old 190E Mercedes fun to drive? I haven't driven one yet.
yupididit
yupididit Reader
3/11/15 7:40 p.m.
Not really. Most Mercedes don't have LSD or a rear that'll take the punishment. If he's looking cheap but good handling. I suggest: C4, 240sx, fc rx7, GM G-body, F-body, and foxbody.
EvanB
EvanB UltimaDork
3/11/15 8:46 p.m.
Volvo 240s are good for swaps. Roomy engine bay and the rear axle is a Dana 30 with numerous locker options.
yupididit
yupididit Reader
3/11/15 9:23 p.m.
Dangs http://inlandempire.craigslist.org/cto/4883159926.html
penultimeta
penultimeta New Reader
3/12/15 8:55 a.m.
Supposedly the volvo 700/900 series do a little bit better with an LSx. I've heard the best candidate is a mid-'90s 960 due to availability of parts and lack of rust. Most are autos though, so you'd be doing a full swap if you're trying to go manual.
evildky
evildky SuperDork
3/12/15 9:39 a.m.
Early rear wheel drive maxima, same basic chassis as the Z but who would think thats packing an LS.
wspohn
wspohn HalfDork
3/12/15 10:09 a.m.
What are you after, sports car or lead sled?
If the former, the Kappa GM platform was built to accomodate the LS engines, and you can pick up the 4 non turbo NA versions quite cheaply these days, although it you go up a couple of years it is worth getting the LSD (same diff used in the Caddys).
The advantage is that no modding of the rest of the car is necessary - brakes, traction control etc. all work. You can pretty much drop an LS7 with Tremec 6 speed into one if your wallet can take it.
LS3 - https://www.youtube.com/watch?v=trvI32NgLZY
DanyloS
DanyloS New Reader
3/12/15 8:43 p.m.
928 ?
RexSeven
RexSeven UberDork
3/12/15 8:46 p.m.
Starquest? Old RWD Celica or similar J-tin?
RX-7s and 240SXs are the "easy" button for light-weight LS swaps. Maybe the swap kits aren't the cheapest option but if you get a chassis and engine cheap enough then that may offset the costs enough to stay cheap.
taparsons
taparsons New Reader
3/14/15 9:26 p.m.
Rx7 is probably the way I will go. How are the trans/ rearends at holding up?
wRSycrHjUhaFgjfBU1B6UgGUMY1vNb18FVuraIM6TNnOS02uO9m7FO0KeroEJWfB
