benzbaron
benzbaron Dork
9/27/11 10:54 p.m.
Ok I was dicking around today and using an older power drill and the damn thing just didn't sound right. It almost sounded like it had a bad bearing in it. Well being broke and unemployed I pull the thing apart. There was about 1/2cup of nasty grease lube in the gear case. I cleaned the old dead grease out, put some new grease in and cleaned the motor with electric glide and cleaned all the dust out of the cooling fins for the motor. The noisy bad bearing sound is gone and the thing sounds very good for probably a 30yr old drill. If I was to change the brushes It would probably run even better.
I did the same with my polisher but the polisher had to have the brushes fall out when I pulled the rotor out of the motor. I was able to grease it up and get it back together and it also sounds much better.
So if any of you folks have old power tools which are disappointing you and not performing or making bad noise pull the sucker apart, clean and lube, check the brushes, and you might be surprised by how much better the tool works.
All of my tools are used cast-offs so fixing them and maintaining them is basically the only option unless I buy new stuff. I haven't been very impressed with newer tools though. The old stuff was made much better and keeping an older machine up and running is both economical and I don't end up getting harbor freight junk.
Raze
Raze SuperDork
9/28/11 6:17 a.m.
OOOOOOhhhh, THAT kind of power tool
CanadianTercel
CanadianTercel Reader
9/28/11 6:46 a.m.
Thanks for the tip/reminder!
I have an old black and decker 120v plug in impact gun, has to be 20 years old, works awesome.
motomoron
motomoron HalfDork
9/28/11 7:21 a.m.
This underscores both the upside and downside of living long enough to get old. Stuff you may have bought new has served you well for...how long?
Here's another useful one. Buy a quart bottle of Marvel air tool oil and keep it next to where the air tools go. Every time you put one away at the end of use, it gets a squirt and a blip of air to circulate it.
I wasted 15 minutes the other day getting my air DA sander freed up and running right. I put it away wet a year ago and haven't done any bodywork in ages. I was motivated to get out every air tool and give each one a lube and a wipe.
N Sperlo
N Sperlo Dork
9/28/11 7:25 a.m.
"Lube your power tools!"
That is where I stopped.
1988RedT2
1988RedT2 Dork
9/28/11 8:47 a.m.
Shoot, it's getting to where I need to check and see if I have any tools NEWER than 20 years old!
SX9iDc6lXsIvoEbO9NASYz7oWXNVGRAAm6RsfH3NMTn7V8w48iSM5HtzlPx8LZzT
