10/5/20 4:42 p.m.
Mr_Asa said:
How do you score this?
10 lugs per 8 rollers, and 18 lugs on the drive sprockets, but one "wheel" and a jet turbine for an engine.
Nice!
GM's Workhorse came with a 4 cyl diesel and 10 lug wheels.
frenchyd
frenchyd PowerDork
10/5/20 6:35 p.m.
In reply to buzzboy :
My MG has 4 cylinders and 4 knock offs.  An XKE V12 would either have 12 and 4 or 12 and 20
Correction. MG 4 cylinders 1 knock off
Jag 12 cylinders 1 knock off
ProDarwin
ProDarwin MegaDork
10/5/20 6:39 p.m.
Yeah, I'm thinking there has to be something out there powered by a 3-71 diesel as well, but data on this is not that easy to find.
TurnerX19
TurnerX19 SuperDork
10/5/20 6:57 p.m.
BRM v16, 4 lugs. Oops, edit, Kieth said lugs per  wheel , not per car so 16 cylinders 1 lug.
noddaz
noddaz UltraDork
10/5/20 6:57 p.m.
Javelin (Forum Supporter) said:
REPU has two rotors and six lugs.
So, no cylinders but 2 combustion chambers.  And 6 lugs.
Ok what about the GTK Boxer?  16 lugs per wheel and 8 cylinders.
10/5/20 7:11 p.m.
Keith Tanner said:
My friend Eric (aka Ottawa on the forum) was telling me about his newly inherited MINI. Three cylinders - but it has five wheel studs. That just seems wrong to me. Only 60% as many cylinders as wheel studs. A four cylinder with a five bolt pattern has an 80% ratio. My MG and one of my Miatas have a 200% ratio. The Tesla has DIVIDE BY ZERO ERROR.
So what car has the most out of whack lug nut to cylinder ratio? Any production cars that are lower than 60%?
Five of the six cars I on have NO lug nuts or wheel studs.  The one car I do own with studs has a rotary.
Technically correct is the best kind of correct!
1 liter Focuses are also five lug/three cylinder vehicles.
There's got to be some truck with 10 lug wheels and an inline six.  That's still the same ratio of course.
10/5/20 7:14 p.m.
Ian F (Forum Supporter) said:
Mr_Asa said:
My Mustang came with a 6 cyl and 4 lugs, a nice robust 150%
the 80's Mustang GT was a V8 with 4 lugs - so 200%.
IIRC, it didn't get 5 lugs until the 1994 and the SN95?
The SVO had five lugs.  And a four cylinder.
codrus (Forum Supporter)
codrus (Forum Supporter) UberDork
10/5/20 10:36 p.m.
B-24 Liberator.  12 lugs, 56 cylinders.
03Panther
03Panther Dork
10/5/20 10:36 p.m.
A Gamma Goat had a 3-53 Aluminum driptroit diesel, but I do not know the lug pattern
slowbird
slowbird SuperDork
10/6/20 12:43 a.m.
1991 Mercury Cougar V8 - 160%
1998 Lincoln Town Car - 160%
1997 Ford Probe V6 - 120%
1992 Ford Escort - 100%
laugh
Apexcarver
Apexcarver UltimaDork
10/6/20 9:26 a.m.
My fmod- 2 cyl (2 stroke) with single lugs.
wspohn
wspohn Dork
10/6/20 10:29 a.m.
Damn - I thought I had a winner at 1200% and you come along with 1600%  Wait! Did it have to be a street legal car.....?
Yourself
Yourself New Reader
10/6/20 1:01 p.m.
So, just to stay within the wording of the "rules"... my Elan with center lock wheels has 7 cylinders (4 engine, 2 master, 1 slave) and 1 nut per wheel.  So 700%? Its a fairly high number until someone with drum brakes chimes in.
Edit: Just realized the thread title is "Lug nut / cylinder ratio" not the other way up. So the above should be 1/7 or 0.14285714285714285714285714285714. And I forgot to add in the door, trunk, and ignition lock cylinders. Oh well, next time.
10/6/20 1:03 p.m.
I am loving the way everyone is looking for loopholes. You folks wouldn't happen to be racing drivers, would you?
Matthew Kennedy
Matthew Kennedy Reader
10/6/20 2:33 p.m.
In reply to Yourself :
so by that count, my Volvo has....26 cylinders?
8 (engine) + 2 (master) + 1 (slave, clutch) + 12 (slave, brake) + 3 (lock) = 26
Do we get to count hydraulic lifters as cylinders? If so, I'm up to 42 cylinders!
These always struck me as wrong:
10/6
8/6
<5 lugs=truck in my tiny brain.
pointofdeparture
pointofdeparture UltimaDork
10/6/20 3:47 p.m.
Saron81 said:
This is the opposite... 4 cylinders, 3 studs!
Do center lock wheels count?
Renault parts binning eventually led to the early Alpine A310 V6 models using 3-lug hubs, which did not last very long in production (presumably because of V6 torque).
ProDarwin
ProDarwin MegaDork
10/6/20 3:59 p.m.
What about the shocks & automatic transmissions?  Both have cylinders/pistons.
10/6/20 4:45 p.m.
Wells Fargo stage coach?  Single nut for each wheel, and the number of cylinders depends on how many revolvers the guards are carrying. :)
SIRJtZpiCFrUihkgxLRAmktTTIgggme4DRyLz3XCoCHi85H5CFe8FMAqDxf5w5Yr
