ChrisLS8 (Forum Supporter)
ChrisLS8 (Forum Supporter) Reader
12/10/20 1:55 a.m.
Living in the bay area for my newest project car I've noticed the pricing for machine work seems to be out of line for what I recall paying but inline for the expectations of the area I live in. I'm in the final stages myself but my friend is currently begining his Big turbo SR build and is gathering info
I've gathered some average pricing for reputable machine shops in my area and have some to compare to people in other areas. I'm debating if it would be cost worthy for my friend to ship his block somewhere to have the work done or just suck it up and do it here. All pricing is for a 4 cyl SR20VE aluminum long block.
Line hone for main studs and set main bearing clearances-650-700. This is high in comparison to prior build in WA by almost double
Installing valve springs and retainers 400-450 (I already did this myself for him but wanted the numbers for comparisons sake)
Resurface block and head. 160-185 for each surface.
Balance rotating assembly 450-600
Hot tank block and head-150-200 each I already did this myself with a home brew setup but again for comparison.
Deglaze bores- 30-40 per cyl. Again I do my own deglazing but I don't know what that normally goes for since I always DIY.
Lower block assembly (pistons,rings,rods)-1500-2000. Again I own all my own bore guages and vernier mics so I would do his engine assembly. Does this sound about right?
Machine 11mm head studs to 1/2 -600-750.
Obviously some of these are already taken care of but for data's sake I figured I'd include them. It's been forever since I've had extensive machine work done so my memory of pricing is fuzzy and I'm trying to make sure my friend gets his money's worth.
Obviously prices have gone up on everything over the years and different regions have different COLs and regulations but does any of this stuff seem out of line price wise or is it fine?
Rather pay more for quality work all things considered.
matthewmcl (Forum Supporter)
matthewmcl (Forum Supporter) HalfDork
12/10/20 7:32 a.m.
Many years ago I shipped a VW 020 transmission from So. Cal. to BSI Racing in Florida. Shipping there and back and paying for a rebuild was cheaper than buying a rebuild and less than half the price of getting it done locally.  Shipping is expensive, but it is a drop in the bucket compared to Bay area labor rates.  I would vote for shipping to a known specialty shop as being an economical option.
asphalt_gundam
asphalt_gundam New Reader
12/10/20 7:37 a.m.
Those prices are in outer space IMO... and engine machining was my profession for 8 years.
It may be just that that's the cost of making a living in the area but I'm going to be dropping off a V8 block for bake/blast/tumble, magneflux, line hone with studs, Bore .068, torque plate hone, square deck, and install cam bearings. All of which will be around 800 here in MN. 10 Years ago I'd do all that and shoot paint on it for $740 and that was making decent money....
Line hone with studs is a 2hr job if you milk the crap out of it....They charging $325+/hr??? I expect any 4cyl job (or V8 for that matter) to be under 1hr...That's chase the threads, debur the main saddles and check for flat, cut caps (or granite block sand if all 5 are one piece), debur caps (edges and holes), install studs, install caps, cycle studs/nuts 3 times (as recommended by fastener manufacture), and hone to spec.. Done right the hone is a quick job of less than .005 to be removed...even less if the caps are sanded and not ground.
stuart in mn
stuart in mn MegaDork
12/10/20 7:43 a.m.
I don't have any idea of relative costs, but the bay area is one of the most expensive areas of the country.  Also, shipping large, heavy items like engine blocks or cylinder heads won't be cheap so you need to weigh the total costs against that.
BoxheadTim (Forum Supporter)
BoxheadTim (Forum Supporter) MegaDork
12/10/20 7:51 a.m.
Given the general cost of living in the SF Bay Area and the cost of commercial real estate there, I can't say that I'm hugely surprised that the cost for machine shop work is considerably higher than in other parts of the country.
If I were the OP, I'd have a look in Stockton or other large towns in the Central Valley to see if the price difference is worth schlepping the components there.
Toyman01 (Moderately Supportive Dude)
Toyman01 (Moderately Supportive Dude) MegaDork
12/10/20 8:21 a.m.
Price list for the shop local to me with the best reputation.
Domestic V8's Small Block
(NON-L.S.)
SHORT BLOCK
IRON HEADS
BASIC CHECK
BASIC CHECK
Check Cylinders
Disassemble, clean, check for
Check Crank
cracks, check guides, check valves,
Vat Block
55
check springs and check surface.
60
Check block for cracks
30
Other check out work/patch
Pressure check for coolant leaks
80
Install Cam Bearings + parts
40
Vacuum check for compression
35
Install Freeze plugs + parts
25
Check surface
0
Deck Block / Square to crank
100
Broken bolt / usually…
25
Check line bore
45
Rebuild / Machine work
Line hone block
125
Basic valve job (after check out)
115
Rigid hone cylinders
50
Basic valve job (includes check out)
175
Deglaze cylinders / flex hone
25
Multi angle / high flow valve job
250
Install sleeve ( plus parts)
125
Street port job (NO polishing)
175
Bore & hone to next size
150
Mill head gasket surface
80
Hone with torque plate add
75
Install 8 hard seats (plus parts)
75
CRANKSHAFT
Install 8 valve guides (plus parts)
50
Check and polish
45
Install 16 valve guides (plus parts)
75
Chamfer oil holes and polish
55
Cut for PC seals
45
Grind crank
150
Cut for aftermarket springs
45
Grind crank plus chamfer
175
MISC
Balance engine
175
Machine for screw in rocker studs
CONNECTING RODS
SBC & SBF, all others POR
125
Pistons on rods
50
Clearance block for 383 stroker
175
Clean and check rods for size
50
tap oil galley for screw in plugs
45
Recondition rods / your stock bolts
85
Surface flywheel
50
Recondition rods /your ARP bolts
100
Change ring gear
45
Change/ fit pin bushings + parts
80
Same Shop, LS price list.
LS Chevy
SHORT BLOCK
CONNECTING RODS
BASIC CHECK
Pistons on rods
50
Check Cylinders
50
Check Crank
Hone rods to size (if tight)
50
Vat Block / iron block
55
Recondition rods for +.002 bearings
85
Check block for cracks / iron
30
80
Ultra sonic clean alum. Block
65
Hone for floating pins
65
HEADS
40
BASIC CHECK
Deck Block / Square to crank iron
100
Disassemble, ultrasonic clean,
Deck Block / Square to crank alum.
125
check guides, check and face valves,
Check linebore
65
check surface.
60
Hone line bore to increase size
75
Linebore block
150
80
Rigid hone cylinders with plate
125
35
Deglaze cylinders
40
Check surface
0
Install sleeve iron ( plus parts)
125
20
Install sleeve alum. (plus parts)
165
200
175
Bore 5.3 to 5.7
300
250
Bore 5.7 to 6.0
300
Street port job (NO POLISH)
175
Bore 6.0 to 6.2
275
90
CRANKSHAFT
Cut guides for PC seals
45
Check and polish
45
55
Grind crank
150
175
Balance engine
175
Install reluctor ring
35
Tack weld reluctor ring
20
Cut keyway
100
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) Dork
12/10/20 8:37 a.m.
2-3x what I am used to here out on the east coast with a few good shops nearby that are always busy and can charge a bit of a premium.
NOHOME MegaDork
12/10/20 9:10 a.m.
In reply to ChrisLS8 (Forum Supporter) :
Yes those prices are way high for the value they provide. But you live in a state and city  where people have to pay millions of dollars if they want to live inside some kind of solid structure. How else are they going to get the $$$
CAinCA
CAinCA Reader
12/10/20 9:26 a.m.
Commercial real estate prices are crazy here.
Residential real estate prices are crazy here.
Salaries are crazy expensive here.
IMHO you need to be billing $200 hour per hour to make a living here (Gilroy). In the Bay Area proper you probably need to bill more than that.
I'd find a specialty shop and ship it out.
californiamilleghia
californiamilleghia SuperDork
12/10/20 10:29 a.m.
I had a Corvair with a bunch of work orders in the paperwork ,
my favorite was $600 to flycut  a pair of Corvair 140hp  heads,
This was in the SF Bay area  and 10 years ago !
z31maniac
z31maniac MegaDork
12/10/20 10:44 a.m.
My first thought as well was check in Sacramento.
asphalt_gundam
12/10/20 10:48 a.m.
This explains my new neighbors...They moved from California to MN. Said their home burned down in the 2019 fires. Despite the large insurance pay out it was impossible for them to buy anything that fit their family of 5. Rent was going to bankrupt them within a year (two gainfully employed at good paying job adults) so they packed what they had left before they ended up homeless and moved here. Say they are way happier and better off here and have no idea why they bothered with California to start with because of a "high paying job".
12/10/20 10:49 a.m.
In reply to z31maniac :
Good point, and maybe Gilroy/Salinas as well. I mainly thought of the Stockton/Manteca/Modesto area because that was the "quickest" to get to from the places in Silly Valley that I usually work(ed) at, and those are at the Southern end - like Sunnyvale, Los Gatos and San Jose.
If the OP is at the Northern end of the Bay it might also be worth checking Santa Rosa and the general area around it.
APEowner
APEowner Dork
12/10/20 10:50 a.m.
Were they actually fly cut or was it a different operation.  Corvair combustion chambers are in a bore in the cylinder head and the cylinders seal against the face of the bore.   Cleaning up the head to cylinder seal requires a special setup with a boring bar.  Fly cutting wouldn't really do anything.
12/10/20 10:54 a.m.
In reply to asphalt_gundam :
I've had that discussion a few times with candidates when I was working for a company that was at Lake Tahoe. "But in the Bay Area they're paying 50% more than you're willing to offer".
Yes, but the cost of living down there at that time was over 100% more...
Of course with 'VID, a whole bunch of people moved from the Bay Area to Tahoe, so that's not true anymore.
californiamilleghia
12/10/20 11:22 a.m.
We always called it "fly cut"   ,machining the mating surface where the cylinder top edge seals.
Tom1200
Tom1200 Dork
12/10/20 11:45 a.m.
If their overhead is higher than the rates make sense. For the record those rates are much higher than my local shops.
Mr_Asa
Mr_Asa SuperDork
12/10/20 12:48 p.m.
Jesus.  I think I paid $500-600 for everything I needed for the rebuild of my truck's engine.
12/11/20 4:39 p.m.
Thanks for all the input. I figured the pricing was out of line. Shipping isnt too bad if you do it right. It usually costs me about 150 bucks to ship a heavy FWD 6 speed transmission across the country in a small wooden crate.
The block and misc parts would be less than half that just weighing them in my head real quick. Gonna start looking for some quality shops in the Midwest or even east coast
WKkohZs4fTe3saI4MJDANqnPByuew2mAxIrbD5YNQUfHRuXjX4rhdvOEPUonP3fJ
