ignorant
ignorant SuperDork
9/30/10 7:47 p.m.
Found this while going around the internet.
Seems to be some issues with Mapp Gas Cylinders..
so.. FWIW.. http://www.bernzomaticinjuries.com/index.html
Looks Scary, anyway, be safe out there..
mad_machine
mad_machine SuperDork
9/30/10 8:02 p.m.
scary... very scary
Jensenman
Jensenman SuperDork
9/30/10 8:04 p.m.
That's why I don't drop MAPP gas cylinders.
mad_machine
9/30/10 8:06 p.m.
well, I can't say I ever planned to drop one.. except maybe from a high bridge onto concrete below
Toyman01
Toyman01 SuperDork
9/30/10 8:18 p.m.
mad_machine wrote: well, I can't say I ever planned to drop one.. except maybe from a high bridge onto concrete below
Hmmm, I wonder if the torch would stay lit.
I can't imagine having a MAPP cylinder rupture if you knock it over. I wonder if they are having similar problems with the propane cylinders. I use them a lot more than MAPP.
Taiden
Taiden Reader
9/30/10 8:22 p.m.
holy crap. that is scary.
triumph5
triumph5 HalfDork
9/30/10 8:48 p.m.
Designed to fail, but an 8ft flame!!!!! Forwarded this to all I know who use the stuff. Big thanks for the heads up, not-so-"ignorant." I use mapp gas much more than propane; good thing I use the old style burner without a built-in igniter. I'm holding the tank when using it, not putting stress on the screw fitting. Still, made me pause.
vwcorvette
vwcorvette Reader
9/30/10 8:56 p.m.
We believe the trigger locking mechanism is also a design defect, because it allows the user to hold the cylinder rather than the torch handle, which can stress the vulnerable portion of the cylinder.
Why does this statement seem backwards to me? Doesn't it make more sense to hold the cylinder? OR am I reading this incorrectly?
triumph5
triumph5 HalfDork
9/30/10 9:05 p.m.
The only way that could make sense is if the igniter top is LOTS heavier than the bottle, which doesn't seem right, but......for me, I'll hold the cylinder.
ignorant
ignorant SuperDork
9/30/10 9:45 p.m.
yeah.. some of the "investigative work" is fairly thin on that site. But it made me stop and think, can't be too careful, especially with 3 mouths now depending on me.
Toyman01
Toyman01 SuperDork
9/30/10 9:52 p.m.
It reads to me like if you were holding the torch head and hit something with the tip all the load is on the torch not the tank. If you are holding the tank and hit something with the torch not only is the load transferred to the tank but there it a lot more leverage.
Travis_K
Travis_K Dork
10/1/10 1:53 a.m.
It appears to me that what they are saying is this:
The torch is designed to snap off above the valve if it is dropped or otherwise hit by something. If you are using one and holding it by the tank (or set it down and it falls over), rather than the torch snapping above the valve, it will snap the top off the tank like in the pictures. For it to become an issue you will have already had an accident, its just that the designed in safety feature fails to work.
patgizz
patgizz SuperDork
10/1/10 8:25 a.m.
i use it all the time doing plumbing work and it bounces around in my truck/van/trailer. have had the same bottle for over a year.
RandyS
RandyS Reader
10/1/10 10:15 a.m.
If it had an 8 ft flame coming out of it then don;t you think the paint on the bottle would be burned. I see no evidnece of an flame. Looks like an ambulance chasing lawyer trying to get a class action suit going.
paanta
paanta New Reader
10/1/10 10:39 a.m.
RandyS wrote: If it had an 8 ft flame coming out of it then don;t you think the paint on the bottle would be burned. I see no evidnece of an flame. Looks like an ambulance chasing lawyer trying to get a class action suit going.
I dunno. At that pressure, the tank might vent gas so quickly that the flame doesn't extend all the way back to the location of the rupture. My can of starter fluid doesn't melt when I use it as a flamethrower.
pilotbraden
pilotbraden Reader
10/1/10 10:54 a.m.
Exactly. When a propane bottle is shot next to a lit road flare there is not any scorching of the bottle. Or so I have heard.
mad_machine
10/1/10 12:09 p.m.
We need to do a test!
alfadriver
alfadriver SuperDork
10/1/10 12:19 p.m.
http://videos.howstuffworks.com/discovery/33060-mythbusters-exploding-propane-tank-video.htm
http://dsc.discovery.com/videos/mythbusters-propane-rocket.html
they do fun stuff on that program.
DWNSHFT
DWNSHFT Reader
10/1/10 1:08 p.m.
Referenced site is clearly class-action attorneys.
EricM
EricM Dork
10/1/10 3:07 p.m.
I used Mapp Gas in our potato gun.
oldtin
oldtin HalfDork
10/1/10 4:50 p.m.
dropped a bottle of mapp gas off the tailgate of my bronco. The cylinder shot itself about 30 yards down the driveway and across the street. Flame was off at the time.
Appleseed SuperDork
10/1/10 5:35 p.m.
I'll believe it when you show me the rest of the cylinder and the torch that was used on it. I've used those things for years, with occasional abuse, without fail.
93gsxturbo
93gsxturbo Reader
10/1/10 6:28 p.m.
I just store mine with the tank and nozzle separated, ever since my dad just about beat my ass because I knocked over his torch and the fracture grooves on the nozzle worked as intended.
Class action lawyer bullE36 M3. You should be embarrassed for posting that link. Working on anything with open flame and a compressed flammable gas cylinder has inherent risks. Damage to the cylinder is just one of them. Do your torch tanks have tip-over caps on them at all times? Thought so.
ignorant
ignorant SuperDork
10/1/10 6:47 p.m.
93gsxturbo wrote: You should be embarrassed for posting that link.
I do believe that is the dumbest thing ever said on this board.
I had a whole response written, but that doesn't deserve one. Have a nice day mr. curmudgeon.
ignorant
ignorant SuperDork
10/1/10 6:50 p.m.
I originally found this on the smokstak.
http://www.smokstak.com/forum/showthread.php?t=81169
One of the guys on there has a defective tank. Looks like something went bad in their process. Maybe this info is helpful to someone.
hotlinked for pleasure
1elKp8AevrVXH8GxDq9aV4yMZgjBoaecn90x1JGUvZTICB7SRcy0Ote7yetym4J0
