_
_ Dork
11/4/19 10:20 p.m.
I want to do some design in my plastidip paint job. But I can't think of what to use to mask off a line between two different paint colors. You cant lay tape over dip, it'll peel it off with the tape. I know you people are geniuses. Let's here it!
aircooled
aircooled MegaDork
11/4/19 10:41 p.m.
There is low stick tape.
Saran Wrap, clingy style?
_
_ Dork
11/4/19 10:50 p.m.
In reply to aircooled :
I could maybe give it a test. Not sure about the Saran Wrap, maybe as a squiggly design... I can't imagine getting a clean, straight line from Saran. I have a hard enough time getting it off the roll!
Ransom
Ransom UltimaDork
11/4/19 11:19 p.m.
If not low-tack tape, then a chemical barrier? Vaseline, mayonnaise, etc...
Not that you're going to get a straighter line than you can draw that way.
_
_ Dork
11/4/19 11:26 p.m.
In reply to Ransom :
a Mayo line had me laughing.
11/5/19 12:01 a.m.
If you put enough thick coats on the base color and let it dry, you can use low tack painter's tape. Run a test peice first, of course.
ebonyandivory
ebonyandivory PowerDork
11/5/19 2:48 a.m.
Will a long strip of magnet stick well enough?
FieroReinke
FieroReinke New Reader
11/5/19 2:53 a.m.
Fill ziplock bag with vaseline and the  cut small bit of the corner off.  Squeeze and draw just like cake decorators do.  More you cut from the corner the wider the strip.  Not sure if it will pull up the surrounding plastidip but it's worth a try
Robbie
Robbie MegaDork
11/5/19 5:04 a.m.
What about vinyl cut tape?
The stuff that has a steel wire in it. You put it down first and then vinyl over it so when you pull it up it cuts the vinyl. Maybe you can get that to not stick very well to your first layer.
wae
wae UltraDork
11/5/19 5:14 a.m.
In reply to Robbie :
I also came in here to recommend knifeless tape.  I was thinking that you might put masking tape down first and then use knifeless tape along the edge so you would get a good cut of the plastidip and then peel the tape off to harmlessly remove the no-longer-connected overspray.
RealMiniNoMore
RealMiniNoMore PowerDork
11/5/19 7:26 a.m.
Yellow Frog tape. That stuff barely sticks, but in a good way.
maschinenbau
maschinenbau SuperDork
11/5/19 7:51 a.m.
I used 1/4" striping tape from Summit over 1 or 2 thin coats of rustoleum. It mostly played nice.
https://gfycat.com/scholarlyfailingkudu
Curtis
Curtis UltimaDork
11/5/19 8:03 a.m.
How about the press-n-seal saran wrap stuff.  Super light adhesive.  Like this:
Image result for glad press'n seal wrap
Saron81
Saron81 Reader
11/5/19 11:10 a.m.
Stencil? Hold it up and spray?
AngryCorvair
AngryCorvair MegaDork
11/5/19 11:22 a.m.
wet paper?
_
_ Dork
11/5/19 12:48 p.m.
I did that last time. It didn't work. You don't get sharply defined lines that way.
_
_ Dork
11/5/19 12:48 p.m.
In reply to ebonyandivory :
THAT is a good idea! I think I can make that work.
_
_ Dork
11/5/19 1:00 p.m.
https://youtu.be/jTuV2km43sA
huh? According to the Fonz, you can use painters tape? He said to give the base coat a week to dry. I have some dip on the car now. I'm gonna try this and see if it lifts.
11/5/19 1:21 p.m.
What about the mylar stuff used for stickers?  Make a pinstripe of it and then kiss it with a hair dryer.  I forms to the texture.
_
_ Dork
11/5/19 1:29 p.m.
In reply to 914Driver :
Not sure I understand.
Saron81
Saron81 Reader
11/19/19 8:20 a.m.
Just saw this stuff:
oo3RUYHLouCYMsqXkCUIsEFNpUCoSGXETszi8zlgOWJ8Kd67DjwCnqh8635gMOZf
