I currently have an NA miata, I also currently have a lexus 1uz 4L DOHC v8. They will be put together, I'm just having second thoughts on transmission choices.
Recently I noticed you can adapt the 1UZFE to a Mazda FC3S RX7 transmission. (fine print in ebay ad HERE )
I don't quite understand rotary nomenclature; but I am under the impression that the 13b would have the same bellhousing pattern (with different starter and slave cylinder locations). As the starter in in the v of the lexus engine and the flywheel is custom, that shouldn't matter.
From what I understand with roatary transmissions, there are a few options. There is a NA box with little changes throughout the years (called a SA for early trans FB for later trans?), there is a turbo box on the T2 (called a model R?), there are ND boxes (which look a lot like the T2 box) and there are rx8 boxes, which I have no idea what they share in common.
From what I understand the non turbo rx7 transmissions can be mix and matched with the miata transmissions. It appears that the "bellhousing" and "tailshaft" can be swapped from the transmissions with modification or swapping required on the input shaft. This is mostly done by Rx7 guys to get the miata ratios and newer boxes in their cars.
nonturbo bellhousing and miata bellhousing
To add to that knowledge, the turbo box differs from the NA boxes with a different bellhousing (is wider to hold a larger clutch/flywheel, and separates from the transmission at a different point). The transmission is beefier. But what I believe is true is the "tailshaft/shifter turrent" is still a similar design and can be swapped. This is where I'm assuming things.
Pictures for knowledge:
Miata box
Rotary NA boxes
Turbo rotary box
What I want to do, is put the miata's tailshaft/shifter on the turbo 2 transmission. I'm not sure it can be done, but turbo boxes are not easy and cheap to find and I don't want to buy one that wouldn't be what I'm thinking.
non turbo box tailhousing swap, incomplete (the mentioned ballancer is wedge fit on and held with that giant nut) miata rotaries
Non turbo trans(same bolt pattern as miata, with ballancer)
turbo trans
turbo box with tailshaft removed FD box(looks different....)
Comparing 89 FSM's, they look non compatable
TL:DR I want to put a miata transmission tailhousing on a rx7 turbo transmission. I don't know if it will fit. I know I should be able to swap with a 1uz->adaptor->rotary bellhousing->miata transmission PPF and stock diff. What I want is 1uz->adaptor->rotary turboII transmission-> miata trans tailhousing PPF and miata diff.
Thanks for looking!
