JohnyHachi6
JohnyHachi6 Reader
12/2/11 4:55 p.m.
Anyone have one of the A-arm eccentric alignment bolts on hand from an NA miata? Wondering what the inserted length (flange to end of threads) and max diameter (for hole clearance) is.
I have a lowered 280zx that is going to need a set of these to take out the rear toe and I don't want to have to enlarge the existing holes in the bushing sleeves to fit the 300zx bolts if there's something smaller that will fit.
Thanks!
mith612
mith612 Reader
12/2/11 9:15 p.m.
If Keith et al hasn't chimed in by then, I will measure the ones I have on hand tomorrow
JohnyHachi6
JohnyHachi6 Reader
12/2/11 10:43 p.m.
Awesome - Thanks.
Keith
Keith SuperDork
12/3/11 9:28 a.m.
I'm at Thunderhill for the 25, so I'm no help on this one right now.
mith612
mith612 Reader
12/3/11 12:16 p.m.
So the picture should be pretty self explanatory. Overall insertion depth is 95 mm. Due to the slot in the bolt that the eccentric cam rides in, you have a useable depth from 55 to 78 mm. The bolt itself is just under 12 mm the entire length.
JohnyHachi6
JohnyHachi6 Reader
12/3/11 2:52 p.m.
In reply to mith612:
Thanks a ton - much appreciated.
jm9QZo7svbAlk02nPrS8tuxvSW6MlODQ8WxPXwVtTpvEOPJ93X6IkUHwJN8JBbHe
