Desmond
Desmond HalfDork
2/25/16 9:02 p.m.
Hey all,
So I had to replace the thermostat on my 99 NB awhile back. When I did so, I used one of those sticky gaskets and no gasket-maker. Maybe I did something wrong (some say use gasket-maker even with the sticky gasket), but the stupid thing developed a massive coolant leak. I finally got around and redid that, this time with gasket-maker, and I've had zero issues.
During the time when it was leaking, my belts would squeak pretty bad when coolant dripped on them. I figured now that I wasn't leaking, the belt squeak would go away. Wrong!
Aside from this, I had a nasty rattle at 3k rpms. I figured it was heat shield, as I've seen this problem personally many times on many different cars. False!
It turns out my lower alternator pivot bolt has completely backed out. I loosened the belt and tried to screw it back in. It screws in until it reaches a certain point, then it just spins. So, obviously stripped.
I jumped online thinking I could just find a similar bolt and run it through with a nut on the end, call it a day. Well, surprisingly nobody had measurements for the bolt (at least that I could find). I bought one that I think might work, but I wondered if anyone here by chance new of the correct size, or maybe a more simple fix to this issue. From what I've read, its not exactly uncommon.
The bolt doesnt necissarily need to be tight, right? It just serves as a pivot point, so it simply needs to never back out again...or is this wrong? If I could get a drill under there, I could put a hole through the end of the bolt and put a cotter pin through it to prevent it from backing out.
WildScotsRacing
WildScotsRacing Reader
2/25/16 9:30 p.m.
"Keith, cleanup on isle 5..."
KazeSpec
KazeSpec New Reader
2/25/16 10:01 p.m.
the alternator pivot bolt needs to be fully tightened after the belt is tensioned. Any allowance for movement can change the tension on the belt and cause squealing.
-Henry
Brokeback
Brokeback Reader
2/25/16 10:16 p.m.
I lost the alternator tensioner bolt on my 90 Miata in an exciting fashion while 600 miles from home, and had to find a replacement - unfortunately, not the pivot bolt! I remember hearing a clunk that sounded an awful lot like a bolt rattling around in the engine bay then falling on the ground, and then the belt got pushed around on pulleys and shredded before I could pull over.
If you can't find the size/type, I can pull mine off and take it to the hardware store and find out :-)
RedGT
RedGT Reader
2/25/16 11:09 p.m.
Wish I could help but when this happened to me I just rooted through an entire garage full of old standard hardware, found one the right length, powered it through the remaining threads, stripping them out of course, and put a nut in the back of it. There. Fixed it! Probably not the solution you were looking for but it did work for over a year til I sold the car.
T.J.
T.J. UltimaDork
2/26/16 4:42 a.m.
I hate that alternator bottom bolt.
Apexcarver
Apexcarver PowerDork
2/26/16 9:01 a.m.
Brokeback wrote: I lost the alternator tensioner bolt on my 90 Miata in an exciting fashion while 600 miles from home, and had to find a replacement - unfortunately, not the pivot bolt! I remember hearing a clunk that sounded an awful lot like a bolt rattling around in the engine bay then falling on the ground, and then the belt got pushed around on pulleys and shredded before I could pull over. If you can't find the size/type, I can pull mine off and take it to the hardware store and find out :-)
IIRC, its the same pitch and diameter as the spare tire and jack holddown. Just measure for length.
(I sheared one awhile back...)
calteg
calteg Dork
2/26/16 9:55 a.m.
IIRC, its the same pitch and diameter as the spare tire and jack holddown. Just measure for length. (I sheared one awhile back...)
That is brilliant. This is the reason I love GRM
Knurled
Knurled MegaDork
2/26/16 10:16 a.m.
Belts squeak forever once coolant soaked.
Brokeback
Brokeback Reader
2/26/16 10:24 a.m.
Apexcarver wrote: IIRC, its the same pitch and diameter as the spare tire and jack holddown. Just measure for length. (I sheared one awhile back...)
I'll bust out the ruler when I get home! My spare is underneath the car, and my jack is no longer there - AAA is much easier, plus weight savings!
2/26/16 11:41 a.m.
Earlier Miatas used a nut and bolt on that pivot. It's less convenient to use, but an easy fix.
99% sure that bolt is a 10x1.25.
Knurled
Knurled MegaDork
2/26/16 1:27 p.m.
3/8" allthread and a pair of nuts is pretty easy to find, too.
2/26/16 2:15 p.m.
Yeah, but then you're That Guy to the next owner.
whenry
whenry Reader
2/26/16 2:23 p.m.
I was thinking that there was a nut and bolt combination too. I do remember stopping in Pikeville Tn on an afternoon drive in my Ex's Yellow to tighten up the bolt when it had come loose. I had to buy a complete set of metric wrenches to get the 12 or 14mm that was needed. Quite an interesting place!
QUqygZ4LvEf4OSzJTM2Rim5c960xDEgIw20x2QTXSKk3gDNEqpR75clw4sYuQ0Vo
