maddabe
maddabe New Reader
11/2/10 10:43 p.m.
I'm deleting air and power steering on my 90 miata. is there a pulley available without the serpentine bit?
  rotating mass =  10 x static mass
Keith
Keith SuperDork
11/3/10 10:46 a.m.
Not a factory one. You can go the Andy Hollis route, take a billet "underdrive" pulley and cut the outside edge off - but then you've removed the damper and that's not a clever plan. I don't think you could cut the outside belt drive off a factory pulley without screwing up the rubber inside but it would be an interesting experiment.
If you want to remove rotating mass from the crankshaft assembly, do it by going to a lighter flywheel. That's the whole purpose of the flywheel, really.
DILYSI Dave
DILYSI Dave SuperDork
11/3/10 10:51 p.m.
Keith wrote: I don't think you could cut the outside belt drive off a factory pulley without screwing up the rubber inside but it would be an interesting experiment.
You can. I've done 2 miata pulleys.
maddabe
maddabe New Reader
11/12/10 12:38 a.m.
In reply to Keith:
So, if you didn't check the "power steering" box you got the same pulley? Seems like a waste to me.
Keith
Keith SuperDork
11/12/10 12:03 p.m.
Well, AC was a dealer-installed option, and you can't have AC without that pulley. And it's part of the harmonic damper. Removing the ribs for the PS/AC drive would have served no purpose other than raising costs and adding a new part number to the mix. So it wasn't a waste at all.
maddabe
maddabe New Reader
11/12/10 1:46 p.m.
I guess that makes sense. Thanks for the input.
Birthdays
HHAEw5cX9uKASKVUDTVmJO2DTCAceijFBU9dEZynZszrUl8iaXD7eM22XF2bpgS0
