JohnInKansas
JohnInKansas Dork
2/24/14 7:38 p.m.
If you had an opportunity to inherit at next-to-no-cost an early-90's that had recently developed an appetite for oil:
  1. is it safe to assume the engine is on its way out? High mileage, but well-maintained.
  2. if the engine was toast, what would you put in it? Shoestring budget if possible, but has to be reliable and reasonably easy to work on.
Aaaaaand go.
whenry
whenry HalfDork
2/24/14 8:17 p.m.
I have opened many high mileage BP motors that still showed its cross-hatching on the cylinder bores. Generally valve stem seals are the weakness and oil burner unless the motor was abused.
fujioko
fujioko Reader
2/24/14 8:23 p.m.
The cheapest solution is swapping in another Miata engine. If you have an early Miata, you could get a '94 and latter 1.8 for a little boost in performance.
If for some reason you wanted less performance, you can drop in an early 90's Festiva engine. it's mostly a nuts and bolts type swap with a bit of fabrication and some mild electronic fabrication. My current Miata has this engine in it.
A three cylinder Geo metro 1.0 can be made to fit but the parts to do the conversion are getting hard to find.
Spoolpigeon
Spoolpigeon SuperDork
2/24/14 8:24 p.m.
Check the basics first. A faulty PCV valve can cause a lot of oil consumption.
xdJBWjlWs1CMQmdSQLwG7zvNc0O7WQtzGf0WloTMKk5uVu3kj1zl7bsX3hAEDLYO
