Snrub
Snrub Dork
1/4/25 11:16 a.m.
I'm considering using R56 Mini Cooper rear springs in an atypical application. Would anyone happen to know the inner/outer diameter of the top and bottom? I'd be appreciative of R50, R52, R56, etc dimensions as i believe they are similar.
DeadSkunk  (Warren)
DeadSkunk (Warren) MegaDork
1/4/25 3:19 p.m.
According to some dimensions on replacement rear springs from Rockauto, OD is 104mmm, ID is 83mm at the top. no bottom dimensions given.
Snrub
Snrub Dork
1/4/25 6:24 p.m.
Thanks. How do you know that's the top measurement and not say the middle?
The site below is where I found these springs. I searched on the sachs spring part number to identify what it was used for. I searched gon Google for mini forums spring rates for different minis.
This site has a great searchable spring database. The url looks sketchy, but it was a top hit on Google: https://size.name/en/catalog/pruzhiny
Edit: I suppose ID is easy to calculate from wire thickness, so it's really OD that I need.
DeadSkunk  (Warren)
1/4/25 9:47 p.m.
In reply to Snrub :
From the pictures of the springs, it appears they are a constant OD except the bottom loop.
Snrub
Snrub Dork
1/12/25 2:38 p.m.
I bought a set of rear mini springs. The OD is 4 5/16" on one end and the pigtail end is 3 1/8 to 3 1/2".
tDAlBu38j2pPQBekJaDb0jSOJjJi9sh7puK5T1dGq9IKKhsgXn424i4RRjZvoUqz
