DeadSkunk
DeadSkunk SuperDork
6/17/14 3:19 p.m.
Mine is making a noise, sounds like the bearing is shot. Various parts sites show a tensioner pulley for $25-35, as well as a tension assembly. Has anyone here actually changed the pulley on the tension assembly, or must I change the whole assembly. The (tension) pulleys listed on the web sites look like the idler pulley to me. I'd like to be sure before ordering anything.
Timeormoney
Timeormoney Reader
6/17/14 7:06 p.m.
what year car? Early models (2002 intro) had the tensioner on a pretty damn stiff spring. The factory tool makes it a pretty easy job to pull the belt. Have you done a pulley swap on the supercharger (assuming early model)
If its a newer one, I haven't got a clue.
DeadSkunk
DeadSkunk SuperDork
6/17/14 7:24 p.m.
2003 CooperS with the stock supercharger pulley.I've seen the special tool to compress the tensioner so you can put the "grenade pin" in it.
Aspen
Aspen Reader
6/18/14 12:57 p.m.
You can get a new Gates tensioner from Rock Auto for about $80. It is the OEM part. That's what I did, why mess around with the pulley when a failure with cause a bunch of extra damage.
SlickDizzy
SlickDizzy PowerDork
6/18/14 1:27 p.m.
Isn't the assembly known for failing and causing supercharger damage on these? If that's true, replacing the whole assembly (and adding a tensioner stop) seems like a no-brainer.
Ian F
Ian F UltimaDork
6/18/14 1:47 p.m.
What Dizzy said: replace the entire assembly.
Get the tensioner tool or see if anyone in a local MINI club will lend it to you.
mJghIthWHkrVJEfwGphYoERSJ5USQWIP7m1ekdRhkVxTObm2CDREsuV9oukkMQlV
