ebonyandivory
ebonyandivory PowerDork
10/14/18 8:49 a.m.
Never owned a Diesel. And I’m in need of something cheap and efficient.
Any experience with these?
1SlowVW
1SlowVW New Reader
10/14/18 9:11 a.m.
In reply to ebonyandivory :
It’s mostly rust that Kills them. Both 1.9td and the first gen tdi are good engines.
For motor and trans make sure you have the chance to start it from cold. Glow plugs are not that hard to change but it’s kind of a tedious job.
if it’s an aaz (non tdi Canada model) check the crank pulley for trueness. They have a key way that likes to shear off and cause valve on piston action.
Either way ask when the timing belt was done last. Make sure there are not leaks at the injector pump, and that there is no air in the lines before they reach the pump.
All mk3 clusters reset the odometer to 0 after 299999 so watch out for low mile examples.
ebonyandivory
10/14/18 9:14 a.m.
In reply to 1SlowVW :
Thank you very much! Great name btw, kinda apropos!
1SlowVW
1SlowVW New Reader
10/14/18 9:19 a.m.
Thanks,
I cut my teeth on 1.6/1.9 idi vw engines... they are really simple little beats.
For what it’s worth I find the mk3 platform is a great driving car, if they hadn’t all rusted into oblivion up here in the rust belt I’d willingly daily one now.
ebonyandivory
10/14/18 9:23 a.m.
I’ve seen a few in Massachusetts that aren’t rusted badly. Seems like a good way to fulfill my car-project need while being an efficient daily driver. Just hoping they can be dependable.
captdownshift
captdownshift PowerDork
10/14/18 7:25 p.m.
they like injector nozzles and reflashes. you'll want a vr6 clutch upgrade which will require a g60 flywheel to mount up. Shine rear sway bars are gold if you can find one in the secondary market. Rust or a timing belt breaking is the only thing that will kill one.
NGTD
NGTD UberDork
10/16/18 9:36 p.m.
As noted the odo's roll at 300000, but when they do, the word Total disappears from the odo, IIRC. So if you see one and you don't see total on the odo, she's on the 2nd pass.
I had a 95 AAZ and it was a great little (slow) car, but the tinworm got bad and I sold it.
i1tr4B8N4vhwc4kFUrZixxKaJOofD8aZWDUkPl2SU6m6xr4KAsz2T5jEf4TEBgac
