malibuguy
malibuguy HalfDork
9/24/23 9:36 p.m.
Ive had this idea to move my lower balljoint mounting point on my control arm, forward and outward to gain caster and camber.
Provided with proper welding and reinforcement (not a problem on my end)...any reason to no do this?  I was thinking half inch in both directions which hopefully does not put the axle out of its range.
9/24/23 9:43 p.m.
No reason not to move it once you can make it strong enough. There are aftermarket LCAs with this kind of adjustment. Only thing to watch out for is to ensure the tie rods have enough adjustment range to gain as much width as you're adding to the control arms.
Noddaz
Noddaz PowerDork
9/24/23 9:58 p.m.
Depending on the control arm, it might be better to do that from the inboard side of the arm.
Cut at the red lines and move forward and out as needed.  And then fill and reinforce the cut marks as needed
9/25/23 9:16 a.m.
On my Rabbit GTI, we fit slightly offset lower control arm bushings to improve caster. Is something like than an option here?
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
9/25/23 12:19 p.m.
There are extended ball joints available for Miatas, not sure about other cars.
Captdownshift (Forum Supporter)
Captdownshift (Forum Supporter) MegaDork
9/25/23 12:35 p.m.
MX3 GS LCAs are the hot ticket for BG chassis cars.
malibuguy
malibuguy HalfDork
9/25/23 1:04 p.m.
We run a 10mm rear bushing mount spacer to gain caster...which results in 0.8⁰ of caster in my cars particular case.
Ive tried finding taller BJs for another car to maybe get a taller one for improved bump steer but my car doesn't suffer from that much since its essentially stock height
mainlandboy
mainlandboy HalfDork
9/25/23 3:01 p.m.
Wouldn't that just get you more camber, and not caster?
DeadSkunk  (Warren)
9/25/23 3:23 p.m.
In reply to mainlandboy :
Yes, but you can also fiddle with the eccentrics on the lower arm of a Miata to shove the ball joint forward a bit to gain caster.The lengthened ball joint gives you back the camber. It's a balancing act.
DeadSkunk  (Warren)
9/25/23 3:26 p.m.
In reply to malibuguy :
What car are you trying to do this to?
Noddaz
Noddaz PowerDork
9/25/23 4:58 p.m.
I am assuming that it is the one in his picture.
malibuguy
malibuguy HalfDork
9/25/23 5:20 p.m.
Went ahead and got one side done.  I only moved it forward for now.  Ill knock out the other side tomorrow.  Also gotta pick up new drill bits lol
DeadSkunk  (Warren)
9/25/23 6:12 p.m.
That's nicely done.
buzzboy
buzzboy UltraDork
9/25/23 8:37 p.m.
Well that escalated quickly. Looks great!
Noddaz
Noddaz PowerDork
9/25/23 9:10 p.m.
It will be interesting once you get this on an alignment rack to see what you get.
malibuguy
malibuguy HalfDork
9/25/23 10:45 p.m.
Thanks guys.  I just realized the picture doesnt so any detail.  Ill take more pictures tomorrow.  I have a side gusset on the inside edge.  Might add one on the outside.
malibuguy
malibuguy HalfDork
9/26/23 10:00 a.m.
Birthdays
S3YLrmbudJyP2qc6mogTal2qFi61uYzhM8uqyTbuWjFsTtVVHT69T1l3yVyzi7LG
