redvalkyrie
redvalkyrie Reader
8/21/16 7:26 p.m.
Not bolted up but looking pretty good.
84FSP
84FSP Dork
8/23/16 6:50 a.m.
Oooh sexy pics.
redvalkyrie
redvalkyrie Reader
11/18/16 10:16 p.m.
Flares on. Cut nearly two inches out of the front fenders. I was rubbing the steel pretty bad with only +3 degrees of caster.
ae86andkp61
ae86andkp61 HalfDork
11/19/16 2:04 a.m.
Lookin reeeeal good!
John Brown
John Brown MegaDork
11/19/16 5:49 a.m.
redvalkyrie wrote: Flares on. Cut nearly two inches out of the front fenders. I was rubbing the steel pretty bad with only +3 degrees of caster.  photo Flares 1_zpsmmy0w6qu.jpg  photo Flares 2_zps22btjzyh.jpg
Where did you get the flares? I'm hoping to cover the 17x10s on the RXh8
redvalkyrie
redvalkyrie Reader
11/19/16 8:14 a.m.
Thanks guys. The flares came from Lithuania which apparently, after the Phillipines, has the market cornered on flares and fiberglass panels. You can check EBay by searching "KP61JDM Flares" or just "KP61 Flares."
redvalkyrie
redvalkyrie Reader
12/27/16 9:18 p.m.
BAM!
12/27/16 9:23 p.m.
Total bam!
redvalkyrie
redvalkyrie Reader
12/27/16 9:28 p.m.
Indeed. No more dizzy. And the weber setup is going to James Inglese for a proper linkage setup.
sesto elemento
sesto elemento SuperDork
12/27/16 9:39 p.m.
Love it.
Trackmouse
Trackmouse Dork
12/27/16 11:27 p.m.
As a fellow Yota enthusiast, you have my approval. (Not that you need it)
Jerry From LA
Jerry From LA SuperDork
12/28/16 1:56 a.m.
Wish I had my old Starlet back now.
redvalkyrie
redvalkyrie Reader
12/25/17 7:02 p.m.
I'm needing to upgrade my 82 Starlet's rear end with either an AE86 or Celica Supra solid rear assembly.  The Starlet,  better known as "Chuppy,"  has been around since 2007 here on the boards.  Well, it's time to go to the next level.
If anyone has one of theses assemblies or knows where to get one, please let me know!  It would be greatly appreciated!
Regards,
John
You can also text me at 918 269 8341
Email:  johnmpruner@gmail.com
DeadSkunk
DeadSkunk UberDork
12/26/17 9:45 a.m.
In reply to redvalkyrie :
Is the AE86 rear end stouter than the earlier TE27 rears? I have a '73 SR5 axle I won't be needing. Where are you located?
DeadSkunk
DeadSkunk UberDork
12/26/17 10:00 a.m.
Never mind.... I looked up the axle code (S292), 6.38" ring, 4.10 ratio and only 2 pinions in the differential. Not very big.
http://www.rallyrace.net/docs/toyota_diff_id.html
redvalkyrie
redvalkyrie Reader
6/25/21 12:31 a.m.
In reply to wheelsmithy :
Super late to respond but...the MC was from either a MR2 or Tacoma.  Works great in my opinion.  Yes, there is more effort in pressing the pedal but not much more.  You get a consistently firm pedal.   The Wilwoods up front are fantastic.  With Toyo R888 tires it stops hard.
Way late update but Chuppy is still alive.
redvalkyrie
redvalkyrie Reader
6/25/21 12:34 a.m.
I have purchased a later model AE86 rear end and a Kaaz LSD.  So,   soon I should be starting on converting the AE86 rear end to fit the Starlet.
I'll also be stroking the engine to 1.5L with the use of some Kameari forged pistons. and a much larger camshaft.   Pics coming tomorrow.
Kreb (Forum Supporter)
Kreb (Forum Supporter) UberDork
6/25/21 12:49 a.m.
Ooh, glad to find this thread. My cousin, nephew and I are doing a Starlet build for Lemons. Parts are difficult to find on these things. Currently modifying a Honda Civic radiator to replace the Starlet.
redvalkyrie
redvalkyrie Reader
6/25/21 3:05 p.m.
In reply to Kreb (Forum Supporter) :
If you need help hunting down parts let me know.  Yup,  I tried an aftermarket aluminum Honda radiator.  Wasn't happy with it so I had the original copper core radiator reworked to new condition.  Works a charm even in Oklahoma 100F summers.  I did the Power Tour in 2016 in June.  That year it ran through Oklahoma.  Everywhere we went it was 100F.  Never had a problem with cooling. However,  I have a Spal electric fan that I can kick on whenever I want.  Just a switched relay.
newrider3
newrider3 Reader
6/25/21 3:39 p.m.
What's your plan to get the AE86 rear to fit, width-wise? We bought an AWD Corolla rear for our Starlet, thinking it was nearly identical to the AE86, and it was going to be way too wide. We ended up narrowing a Ford 7.5 using two short side early Ranger shafts.
We first ran a mid-90s Prizm/Corolla radiator and have now switched to a S13 SR20DET 240sx radiator (due to inlet/outlet differences between the 4k and our swap). Both fit well width and height wise, but different mounts were required for both compared to stock obviously.
Here's the build thread:
https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/1983-toyota-starlet-h27a-v6-swap/163295/page1/
Stealthtercel
Stealthtercel Dork
6/25/21 6:53 p.m.
a) Welcome back!
b) In that last photo, had Chuppy just hit 88 miles per hour, or what?
impg3Cuk5sCstXY0wGVAV8X5XsLvqGtlBo1Uxa1TCD1avKU0YlJukw97p2DmmQfs
